The DAP Shanling M3s with a dual DAC 32bit has a true High fidelity expertise with a low impedance of output, compatible with a wide range of headphones and intras, this DAP offers a real musical quality whatever the type of music.
By buying this product you get 27 loyalty points
The Shanling M3S Hi-RES Walkman with its dual DAC AK4490 design and true symmetrical stages with AOP MUSE8920 and AD8397 X2 offers high-quality sound in a compact format. Capable of competing with streamers and DACs, this DAP will fulfill all your expectations both in public transport and at home. It is obviously usable in USB transport to a compatible DAC or vice versa in DAC USB to a Hifi chain.
The DAP Shanling M3s isHibyLink. It allows you to control the M3S playback application via an Android smartphone or tablet. So the Shanling M3S becomes a high quality USB driver compatible with your DAC or Hifi. You can change songs, raise or lower the volume, edit playlists on your smartphone or tablet. The DAP M3S can of course send Bluetooth 4.1 apt-X on a wireless receiver or any compatible speakers.
| Specifications | |
| DAC | Dual DAC AK4490 32bits 384kHz |
| Distortion rate per harmonic | 0.0015% |
| Bandwidth | 20 to 20kHz +/- 0.015dB |
| Output Power | 130mW (32 Ohms), 230mW balanced balanced output (32 Ohms) |
| Signal Ratio | 115dB A-weighted |
| Output impedance | 0.6 Ohm unbalanced output, 0.3 Ohm balanced balanced outputANCED |
| Separation of channels | 102dB (balanced mode) |
| Internal Clock | Double KDS high precision 22.5Mhz and 24.5Mhz clock with reduced phase distortion |
| Viewing | Screen Retina thickness glass 2.5D |
| Compatibility & Connectivity | |
| USB Type C Compatibility | PCM 44.1kHz - 384kHz 16-32bits, DSD64 to DSD128 |
| File Compatibility | DSF, DFF, ISO, WAV, WMA, FLAC, ACC, ALAC, APE |
| USB DAC Compatibility | Windows 7, 8, 8.1, 10 (requires a drive), Mac OS 10 and Linux |
| Bluetooth | 4.1 aptX |
| Hibylink Wireless Control | Compatible |
| USB Compatible | Windows 7, 8, 8.1, 10 (requires a drive), Mac OS 10 and Linux |
| Connectors | |
| Headphone output | Jack 2.5mm TTRS Symmetrical Balanced |
| Headphones output | 3.5mm Stereo Jack |
| Storage | Micro SD max. 256GB (not included) |
| USB Type-C port | Yes - USB DAC compatible and USB transport |
| Miscellaneous | |
| Food | Through the USB port Type-C 5V DC 2A |
| Case | Aluminum CNC Black |
| Dimensions | 113 x 53 x 14.5mm (WxDxH) |
| Weight | 135g |
| Accessories | 1x USB Cable Type-C |
