AUNE N7 DAC EDITION Balanced Headphone Amplifier Preamplifier DAC
With its N7 DAC EDITION, Aune offers us a versatile device that doubles as a DAC as well as a powerful, discreet, fully balanced Class A headphone amplifier-preamplifier. It's based on a combination of JFET transistors for headphone amplification, an independent Class A preamplifier function and R2R volume control for optimal audio signal processing. The use of JFET transistors delivers a warm, smooth sound that will delight tube enthusiasts.
4.0 / 5
By buying this product you get 52 loyalty points
Reference : 21004
529,00 €tax incl.
440,83 € tax excl.
Shipping date: 26-05-2026.
Aune N7 DAC EditionDiscrete Class A Balanced Headphone Amplifier Preamplifier DAC 2xCS43198 6570mW 32 Ohm 32bit 384kHz DSD256
Aune N7 DAC EDITION
With its N7 DAC Edition, Aune offers us a versatile device that doubles as a DAC as well as a powerful, discreet, fully balanced Class A headphone amplifier-preamplifier. It's based on a combination of JFET transistors for headphone amplification, an independent Class A preamplifier function and R2R volume control for optimal audio signal processing. The use of JFET transistors delivers a warm, smooth sound that will delight tube enthusiasts.
On the DAC side, two Cirrus Logic CS43198 chips enable it to support high-resolution streams up to PCM 32bit 384kHz and DSD256, so you can enjoy the best of streaming platforms or very high-quality local files via a USB-C input.
Add to this an attractive 3" color display and a user-friendly interface for a pleasant listening experience and easy device control. In terms of connectivity, the N7 is well equipped with RCA and balanced XLR inputs, two 6.35mm jack and balanced 4.4mm jack headphone outputs, and two preamplified RCA and balanced XLR outputs.
The Aune N7 advantages
The Aune N7 DAC EDITION chipset
Aune N7 DAC Edition: DAC Cirrus Logic
The N7 DAC Edition features two Cirrus Logic CS43198 chips, enabling it to support sampling rates up to PCM 32bit 384kHz and DSD256 via its USB input. This will enable you to enjoy high-resolution files via streaming platforms or locally for the most enjoyable listening experience.
Aune N7 DAC Edition: JFET transistors for a warm sound
The use of JFET transistors in the N7 offers a sound similar to that of tubes. They provide a soft, warm sound signature, while optimizing signal processing as it enters the device.
Aune N7 JFET transistors
Aune N7 volume control
Aune N7 DAC Edition: R2R volume control
The Aune N7 DAC Edition features no less than 2 JRC volume control chips paired with AOPs to form a balanced 4-channel volume control. This offers extremely precise volume control with high stability between left and right channels.
Aune N7 DAC Edition: a powerful headphone amplifier
By adjusting the gain, the N7 DAC EDITION delivers the output power needed to drive headphones and IEMs with impedances from 16 to 600 Ohms without difficulty. In fact, with a high-gain 32-ohm load, it can deliver up to 6570mW of power.
Aune N7 DCA EDITION headphone output power
Load impedanceUnbalanced headphone outputBalanced headphone output
32 ohm1900mW6570mW
300 ohm213mW750mW
600 ohm106mW370mW
Aune N7 power output
Aune N7 DAC Edition: 3" color screen
The N7 DAC Edition boasts a 3" color screen, a user-friendly interface and a remote control for remote control of device functions.
The Aune N7 screen
Aune N7 DAC EDITION overview
1Single-ended 6.35mm headphone output
2Balanced 4.4mm headphone output
3IR receiver
4Display
5Multifunction button
6USB-C input
7Balanced XLR input
8Single-ended RCA input
9Balanced XLR output
10RCA output
1118V DC power supply via DC jack / Power on
Product typeDAC
Headphone amplifier
Preamplifier
DAC Chip2x CS43198
Inputs1x Single-ended RCA input
1x Balanced XLR input
1x USB-C
Outputs1x 6.35mm single-ended headphone output
1x 4.4mm balanced headphone output
1x Single-ended RCA line output
1x Balanced XLR line output
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD256
Input/output impedance
RCA input impedance10kΩ
RCA output impedance200Ω
XLR input impedance22kΩ
XLR output impedance100Ω
Headphone outputs: 6.35mm jack, 4.4mm balanced jack
6.35mm headphone output measures
Frequency response (20Hz-80kHz)±0.05dB
THD+N< 0.0004% @ 1kHz
SNR> 105dB @ 600Ω
Crosstalk< -100db @ 1khz 600Ω
4.4mm headphone output measures
SNR> 105dB @ 600Ω
Gain-dependent output power
6.35mm headphone output (low gain)570mW @ 32Ω
190mW @ 100Ω
130mW @ 150Ω
79mW @ 250Ω
66mW @ 300Ω
42mW @ 470Ω
33mW @ 600Ω
Balanced 4.4mm headphone output (low gain)2150mW @ 32Ω
720mW @ 100Ω
500mW @ 150Ω
316mW @ 250Ω
270mW @ 300Ω
172mW @ 470Ω
135mW @ 600Ω
6.35mm headphone output (high gain)1900mW @ 32Ω
616mW @ 100Ω
416mW @ 150Ω
252mW @ 250Ω
213mW @ 300Ω
136mW @ 470Ω
106mW @ 600Ω
Balanced 4.4mm headphone output (high gain)6570mW @ 32Ω
2190mW @ 100Ω
1500mW @ 150Ω
900mW @ 250Ω
750mW @ 300Ω
480mW @ 470Ω
370mW @ 600Ω
Dimensions208 x 160 x 83mm
Package1x Aune N7 DAC EDITION
1x 6.35mm jack to 3.5mm jack adapter
1x AC adapter and power cord
1x Remote control
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate384kHz
Max sampling rateDSD256
ClassClass A / AB
Remote ControlYes
Quelques défauts mais l'essentiel est très bon.
Commençons par les défauts:
- L'écran fait un petit bruit tant qu'il est allumé. Pas vraiment gênant mais audible. Heureusement, passé la phase d'allumage de l'appareil, l'écran s'éteint après 30 secondes.
- Le knob ne réagit pas toujours très bien. ça semble être un défaut de série (cf : https://www.head-fi.org/threads/aune-n7-headphone-amp-now-available-pure-class-a-freed-from-size.977918/#post-18827738 )
- Le câble USB nécessaire à son fonctionnement n'est pas fourni. En revanche, un adaptateur 3.5/6.35mm qui ne servira sans doute à personne est inclus. Allez comprendre...
Le son, maintenant.
Venant d'un Aune X1S, c'est le jour et la nuit ; surtout si votre casque est exigeant. J'ai toujours eu la sensation que le X1S ne permettait pas à mon Kennerton Magni de s'exprimer pleinement. C'est désormais du passé avec ce N7.
Bref, le son qui sort du N7 est spacieux, chaleureux et dynamique ; que du bonheur.
This review has been posted for AUNE N7 DAC EDITION Discrete Class A Balanced Headphone Amplifier Preamplifier DAC 2xCS43198 6570mW 32 Ohm 384kHz DSD256
With its N7 DAC EDITION, Aune offers us a versatile device that doubles as a DAC as well as a...
