FIIO IMP XLR-4 Impedance Adapter
New
The FiiO IMP XLR-4 is an impedance adapter designed to connect a headphone to the speaker outputs of a Hi-Fi amplifier. It supports headphones with an impedance of 16 to 300Ω and amplifiers with an output power below 300W, allowing you to benefit from their driving capability while adapting the signal level to the headphone.
Reference : 22703
27,99 €tax incl.
23,33 € tax excl.
FiiO IMP XLR-4 Impedance Adapter
FIIO IMP XLR-4: Front view
FiiO IMP XLR-4: Signal attenuation via voltage divider
An internal voltage divider circuit reduces excess power from the amplifier output before it reaches the headphone. This attenuation also helps limit background noise, particularly with low-impedance or high-sensitivity headphones. FiiO recommends starting with the amplifier level at minimum, then gradually increasing it to the desired volume.
FIIO IMP XLR-4: Voltage divider
FIIO IMP XLR-4: Balanced output
FiiO IMP XLR-4: Balanced headphone outputs
The IMP XLR-4 features two balanced headphone outputs: a 4.4mm jack and a 4-pin XLR connector. This dual connectivity allows compatible headphones to be connected directly, without an intermediate adapter.
FiiO IMP XLR-4: Gold-plated binding posts
Four gold-plated copper binding posts, compatible with 4mm banana plugs, provide the connection to the amplifier's speaker outputs. The plating helps maintain stable electrical contact and protects the connection surfaces against humidity, corrosion and oxidation caused by use.
FIIO IMP XLR-4: Binding post
FIIO IMP XLR-4: Aluminum enclosure
FiiO IMP XLR-4: Aluminum alloy enclosure
Its compact aluminum alloy enclosure contributes to shielding against electromagnetic interference and to heat dissipation during operation. Its format makes it easy to install near a desktop amplifier or a home Hi-Fi system.
Technical specifications
Product typeImpedance adapter
InputsSpeaker binding posts
Outputs1x Jack 4.4mm
1x XLR 4 pins
Compatible headphone impedance16-300Ω
Max input power300W
Dimensions90 x 69.5 x 34.5mm
Package1x FiiO IMP XLR-4
InputSpeaker terminals
OutputJack 4.4mm
ClassN/A
The FiiO IMP XLR-4 is an impedance adapter designed to connect a headphone to the speaker outputs of a Hi-Fi amplifier. It supports headphones with...
