HOLO AUDIO BLISS LEVEL 1 Class A Discrete Balanced Headphone Amplifier
The Holo Audio Bliss Level 1 is a discrete, high-end pure Class A headphone amplifier, offering incredible sound quality thanks to a design based on an optimized and careful architecture, using only high-end electronic components. It also allows to develop an important power of 12W under 32Ω, making it able to accompany any headphone of the market without difficulty.
By buying this product you get 321 loyalty points
Reference : 17092
3 219,00 €tax incl.
2 682,50 € tax excl.
Shipping date: 16-09-2025.
Garantie 3 mois
Holo Audio Bliss Level 1 Amplificateur Casque Class A Discret Symétrique
The Bliss Level 1 has single-ended stereo RCA and single-ended stereo XLR inputs. The device has three headphone outputs on its front panel, with single-ended Jack 6.35mm as well as balanced XLR 4 pins and Jack 4.4mm. The rear of the unit also features a single-ended stereo RCA and balanced stereo XLR output.
Please note: power cable not included.
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Inputs1* Single-ended stereo RCA
2* Balanced stereo XLR
Outputs1* Single-ended Jack 6.35mm headphone output
1* Balanced Jack 4.4mm headphone output
1* Balanced XLR 4 pins headphone output
1* Balanced stereo XLR
Output power12W @ 32Ω
Consumption60W
Dimensions (W*D*H)430*300*67mm
Weight18kg
ColorBlack and coper
Package1x Holo Audio Bliss Level 1
1x Power cable
InputXLR
OutputJack 3.5mm
OutputJack 4.4mm
ColorCopper
ClassClass A / AB
Parfait
Ce Bliss est incroyable en tant que préamplificateur classA HDG. Je l'utilise avec le DAC Holo Sring3 L2 et pour la puissance un ampli Audiophonics HPA Q450ET sur la base des derniers modules Purifi. L'association A/D est magnifique au point que j'ai retiré ma platine vinyle pourtant équipée d'une 2M Black. Comme moi vous pouvez utiliser la deuxième entrée XRL en "by-pass" (gain du Bliss à 0dB) pour le Home cinéma, ça a apporté un plus sur les Fronts.
Maintenant je cherche un casque à sa hauteur.
Si je devais émettre une réserve ce serait l'absence de télécommande pourtant mentionnée dans la Doc. Du coup j'utilise le volume d'Audirvana avec un gain fixe sur le Bliss et en mode puriste j'annule le contrôle de volume d'Audirvana et je joue du volume sur le Bliss. Aucune différence audible entre les 2 méthodes et puis une fois réglé on écoute et on ne bouge plus tellement c'est beau.
This review has been posted for HOLO AUDIO BLISS LEVEL 1 Class A Discrete Balanced Headphone Amplifier
The Holo Audio Bliss Level 1 is a discrete, high-end pure Class A headphone amplifier, offering incredible sound quality thanks to a design based...
