Headphone Amplifier
iFi Audio offers with the Zen Air CAN a powerful and affordable desktop headphone amplifier, allowing you to enjoy quality headphone listening without breaking the bank. Versatile, it will accompany balanced or single-ended headphones thanks to its two front outputs and its different settings.
The Zen Air CAN has three different gain settings, allowing it to accompany the vast majority of headphones on the market, whether they are high sensitivity or high impedance models.
With its two headphone outputs, single-ended 6.35mm jack and S-Balanced 4.4mm jack, the Zen Air CAN is suitable for all situations. Moreover, this last connection allows you to benefit from all the advantages of a balanced connection, i.e. lower noise and less crosstalk, without the need to use balanced headphones.
The Zen Air CAN also provides two functions developed by the brand. The first one, XBass, allows to extend the bass response in an analog way. The second one, XSpace, is an analog spatializer for headphones, aiming to obtain a wider sound stage.
Product type | Headphone amplifier |
Input | 1x Jack 3.5mm 2x Stereo RCA |
Output | 1x Single-ended Jack 6.35mm 1x S-Balanced Jack 4.4mm |
Max output | > 6.7V / 75mW @ 600Ω > 6.5V / 660mW @ 64Ω > 6.2V / 1200mW @ 32Ω |
THD+N | 0.005% @ 100mW/1.27V, 16Ω |
SNR | > 114dBA @ 6.7V |
Max input level | RCA : 3.8V RMS Jack 3.5mm : 1.92V RMS |
Adjustable gain | 0dB 9dB 18dB |
Frequency response | 10Hz - 100kHz (-3dB) |
Supply voltage | 5VDC 2.5A (USB-A to DC jack cable included, AC adapter sold separately) |
Consumption | No signal: ~ 5W Max signal: ~ 13W |
Dimensions | 158 x 117 x 35mm |
Weight | 352g |
Input | RCA |
Input | Jack 3.5mm |
Output | Jack 4.4mm |
Output | Jack 6.35mm |
Color | Black |
Class | N/A |
Remote Control | No |
