SMSL H400 Headphone Amplifier / Preamplifier Silver
The evolution of the H300, SMSL unveils the H400, a compact headphone amplifier/preamplifier now featuring an attractive tempered-glass IPS display on the front panel, as well as a grounding connector and grounded/floated switch. Powerful, the H400 delivers up to 15W of power at 16 ohms and up to 7.5W at 32 ohms.
Reference : 19474
469,00 €tax incl.
390,83 € tax excl.
SMSL H400 Headphone Amplifier / Preamplifier 15W 16 ohms Silver
SMSL H400 picture
The evolution of the H300, SMSL unveils the H400, a compact headphone amplifier/preamplifier now featuring an attractive tempered-glass IPS display on the front panel, as well as a grounding connector and grounded/floated switch. Powerful, the H400 delivers up to 15W of power at 16 ohms and up to 7.5W at 32 ohms. Like its predecessor, it features a 3-level gain control, enabling it to adapt to the majority of headphones and IEMs available on the market. Its balanced architecture and discrete components make it an ideal choice that can also be used as a preamplifier.
Avantages du H400
SMSL H400: a powerful headphone amplifier
With its 15W of power at 16 ohms, the SMSL H400 is one of the most powerful headphone amplifiers on the market. Even at 600 ohms, it's still capable of delivering 550mW of power, while maintaining high performance levels such as an SNR of 133dB and a THD+N of 0.00006% (-123dB, 1kHz, 32 ohms).
Un amplificateur casque puissant
Réglage du gain du H400
SMSL H400: gain control
The H400 features three levels of gain adjustment, enabling it to adapt to the various headphones and IEMs available on the market.
Unbalanced outputsBalanced outputs
LOW-11.8dBLOW-5.8dB
MEDIUM0dBMEDIUM6dB
HIGH14.4dBHIGH20.4dB
H400: high-end preamplifier
On the rear panel, in addition to its analog inputs, the H400 features an RCA line output and a balanced XLR line output, enabling it to be used as a preamplifier. In this way, the H400 can be used as a key link in an audio system between a DAC and a power amplifier, for example.
H400 : préamplificateur high end
H400: a refined appearance
Unlike its predecessor, the H400 features a handsome tempered-glass IPS screen on the front, displaying information on the current playback and allowing you to adjust some parameters.
Un look moderne
H400: IR remote control
An infrared remote control is supplied with the H400 for a smooth, comfortable user experience.
Photo de la télécommande IR du H400
Photo de l'étage d'alimentation du H400
H400: a reliable, stable power supply
SMSL has chosen to integrate a proprietary, low-noise power supply to drive all the components of its H400 headphone amplifier. This power supply provides a clean, stable current to the various stages of the H400, partly responsible for its excellent performance.
SMSL H400 overview
H400 overview
1Display
2IR remote control receiver
3LED indicator
4Multifunction button / Volume control
5Balanced XLR headphone output
6Balanced 4.4mm jack headphone output
76.35mm jack headphone output
8RCA line input
9Balanced XLR line input
10RCA line output
11Balanced XLR line output
12USB-C update port
13Ground connector
14Grounding switch
15Power connector
Product typeHeadphone amplifier / Preamplifier
ArchitectureBalanced
Inputs1x RCA stereo single-ended
1x XLR stereo balanced
Sorties1x Balanced 4.4mm jack headphone output
1x Balanced XLR 4-pin headphone output
1x Single-ended 6.35mm jack headphone output
1x Single-ended stereo RCA line output
1x Balanced stereo XLR line output
Output power2x 12W @ 16 ohms
2x 7.5W @ 32 ohms
2x 1000mW @ 300 ohms
2x 550mW @ 600 ohms
SNR133dB
Dynamic range133dB
THD+N0.00006% (-123dB, 1kHz, 32 ohm)
Input impedance47kOhms
Headphone output impedanceNear 0 ohm
Line output impedanceXLR: 44 ohms
RCA: 22 ohms
Frequency response20Hz-100KHz (-0.5dB)
Gain settingsBalanced outputs:
Low: -5.8dB
Medium: 6dB
High: 20.4dB
Single-ended outputs:
Low: -11.8dB
Medium: 0dB
High: 14.4dB
Power supply100-240V AC
Power consumption< 50W
Standby power consumption< 0.5W
Dimensions254 x 46 x 189mm
Weight2.03Kg
ColorSilver
Package1x SMSL H400 headphone amplifier/preamplifier
1x Remote control
1x Power cable
Mesures du H400
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
ColorSilver
ClassN/A
Remote ControlYes
SMSL H400 Headphone Amplifier / Preamplifier 15W 16 Ohm Silver
The evolution of the H300, SMSL unveils the H400, a compact headphone amplifier/preamplifier now featuring an attractive tempered-glass IPS display...
