SONCOZ QXA1 Balanced Headphone Amplifier Preamplifier Black
The Soncoz QXA1 is both a headphone amplifier and a preamplifier, supported by a high quality balanced architecture, using components selected for their performance and their ability to provide a pure and accurate sound reproduction.
Reference : 15924
299,00 €tax incl.
249,17 € tax excl.
Soncoz QXA1
Soncoz QXA1 Amplificateur casque préamplificateur symétrique
The Soncoz QXA1 is both a headphone amplifier and a preamplifier, supported by a high quality balanced architecture, using components selected for their performance and their ability to provide a pure and accurate sound reproduction. It includes a volume control based on a MUSES 72320 chip and a resistor ladder circuit, ensuring a very low level of noise and distortion, four OPA1642 and four OPA1622 AOPs, ELNA capacitors and a power supply regulation using TPS7A4700 and TPS7A3301 chips. A nice orange LED display clearly shows information about the device parameters.
Moreover, the QXA1 benefits from a complete connectic. It has both balanced XLR and single-ended RCA inputs. On the output side, we find RCA for the pre-output, as well as balanced XLR 4 pins and single-ended Jack 6.35mm for the headphone outputs. The power supply is done in 5VDC via a simple USB-C port.
1RCA input indicator
2XLR input indicator
3Jack 6.35mm single-ended headphone output indicator
4XLR balanced headphone output indicator
5RCA Pre-Out indicator
6Balanced XLR 4 pins headphone output
7Single-ended Jack 6.35mm headphone output
8Volume level indicator
9Gain level indicator
10Multifunction knob
11XLR analog input
12RCA analog input
13RCA pre-out
14USB-C power input (5V 1.5A)
Preamplifier
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Sorties1x RCA pre-out
1x Balanced XLR 4 pins headphone output
1x Single-ended Jack 6.35mm headphone output
Headphone output measurements
Analog inputsXLRRCA
Headphone outputsSingle-endedBalancedSingle-endedBalanced
THD+N @ 1kHz< -116dB< -117dB< -116dB< -117dB
Freq @ 20Hz-20kHz±0.1dB±0.1dB±0.1dB±0.1dB
Dynamic range @ 1kHz, A-Weighting< -122dB< -124dB< -122dB< -124dB
SNR @ 50mV, A-Weighting< -92dB< -91dB< -92dB< -91dB
Crosstalk @ 10kHz< -118dB< -120dB< -118dB< -120dB
Voltage output V=0,G=02Vrms4Vrms2Vrms4Vrms
Output impedance0.1Ω0.05Ω0.1Ω0.05Ω
Noise2µVrms4µVrms2µVrms4µVrms
Output power33Ω1550mW550mW1550mW550mW
300Ω190mW700mW190mW700mW
600Ω95mW350mW95mW350mW
Pre-out measurements
Analog inputsXLRRCA
Pre-outputRCARCA
THD+N @ 1kHz< -116dB< -116dB
Dynamic range @ 1kHz, A-Weighting< -122dB< -122dN
SNR @ 50mV, A-Weighting< -93dB< -93dB
Crosstalk @ 10kHz< -130dB< -130dB
Output voltage V=0,G=02Vrms2Vrms
Output impedance100Ω100Ω
Noise2µVrms2µVrms
general
Supply voltage5VDC 1.5A via USB-C
Consumption< 8W
Dimensions149.3 x 87 x 37mm
Weight550g
Package1x Soncoz QXA1
1x USB-C Power cable
1x Jack 6.35mm to Jack 3.5mm adapter
InputXLR
OutputJack 6.35mm
ClassN/A
The Soncoz QXA1 is both a headphone amplifier and a preamplifier, supported by a high quality balanced architecture, using components selected for...
