TOPPING A30 PRO Headphone Amplifier NFCA Black
The Topping A30 Pro is a high quality NFCA headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at different impedances and a three-level adjustable gain,
Reference : 15140
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 27-05-2026.
Topping A30 Pro
NFCA Headphone Amplifier Black
Topping A30 Pro Amplificateur Casque Symétrique Noir
The Topping A30 Pro is a high quality headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at different impedances and a three-level adjustable gain, it will work with all types of headphones. Its symmetrical amplification circuit allows it to offer excellent performance, ensuring great precision and richness of sound.
On the connection side, the A30 Pro offers balanced XLR or unbalanced RCA inputs. For its headphone outputs, the amplifier offers unbalanced 6.35mm jack, as well as 4-pin XLR and unbalanced 4.4mm jack. The A30 Pro also offers two pass-through outputs with unbalanced RCA or two mono 6.35mm jacks for the balanced output. These are not preamplifier outputs.
Topping A30 Pro Amplificateur Casque NFCA Noir
xxx
NFCA & 10x OPA1656
The A30 Pro takes advantage of the new optimized NFCA circuit to achieve incredible unbalanced performance. The 10 OPA1656 AOPs connected in parallel and the UHGF (Ultra High Gain Feedback) technology ensure excellent AC and DC characteristics. The high current of the Topping A30 Pro allows it to be used with a wide range of headphone models without difficulty. Measured characteristics such as an ultra low noise of only 0.3µV or a dynamic range of 145dB allow the Topping A30 Pro to offer a rich, precise and lively sound reproduction.
A particularly complete connectivity
The Topping A30 Pro offers a complete panel of connectors. We find unbalanced RCA and balanced XLR on the input. On the output side, we find unbalanced RCA but also a balanced output on two pass-through mono 6.35mm jacks, as well as three headphone outputs in balanced 4.4mm jack, balanced XLR 4 pins and unbalanced 6.35mm jack.
Furthermore, in the case of an RCA use with several devices, a GND/LIFT switch allows to cancel the noise that can be generated by ground loops. The LIFT position allows you to use the ground of the connected equipment instead of the A30 Pro.
Finally, we note that in the case of the use of a headphone with an impedance higher than 250Ω, the A30 Pro works in Class A.
TOPPING A30 PRO Amplificateur Casque NFCA Noir TOPPING A30 PRO Amplificateur Casque NFCA Noir
A versatile headphone amplifier
Versatile, the A30 Pro adapts to all types of headphones, notably thanks to an adjustable gain in 3 levels. The amplifier is equally at home with highly sensitive in-ear monitors and high-impedance headphones.
Test of the Topping A30 Pro by Audio Science Review (Amir)
Just when we thought we had reached a plateau with performance of headphone amps, Topping pushes a bit more in the form of lower noise and much more power in unbalanced mode. It goes without saying that it is my absolute pleasure to recommend Topping A30Pro headphone amplifier. "
Test du Topping A30 Pro par Audio Science Review (Amir)
Inputs1x Single-ended stereo RCA
1x Balanced stereo XLR
Outputs1x Single-ended Jack 6.35mm headphone output
1x Single-ended Jack 4.4mm headphone output
1x Single-ended XLR 4 poles headphone output
1x Single-ended stereo RCA (pass through)
2x Balanced mono Jack 6.35mm (pass through)
THD0.00009% @ 1kHz
SINAD121dB
SNR128dB @ Medium Gain, 4V In/Out
95dB @ Medium Gain, 50mV Out, 600Ω
THD0.00009% @ 1kHz
Frequency response10Hz - 30kHz
Measurements
Single-ended inputBalanced input
THD+N @ 1kHz A-Weighting< 0.00007% @ 3.5W, 32Ω
< 0.00006% @ 90mW, 300Ω
< 0.00007% @ 3.2W, 32Ω
< 0.00006% @ 86mW, 300Ω
THD @ 20Hz-20kHz 90kBW< 0.00008% @ 760mW, 32Ω
< 0.00007% @ 81mW, 300Ω
< 0.00007% @ 760mW, 32Ω
SNR @ Max Out, 1kHz, A-Weighting145dB140dB
SNR @ 50mV Out, 1kHz104dB104dB
Dynamic range @ 1kHz, A-Weighting145dB140dB
Frequency response20Hz-40kHz (±0.05dB)20Hz-40kHz (±0.1dB)
Output level34Vpp @ G=L
34Vpp @ G=M
45Vpp @ G=H
6.6Vpp @ G=L
34Vpp @ G=M
45Vpp @ G=H
Noise level @ A-Weighting< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 0.9µVrms @ G=H
< 0.3µVrms @ G=L
< 0.3µVrms @ G=M
< 1.1µVrms @ G=H
Crosstalk @ 1kHz-106dB-101dB
IMD CCIF @ 18kHz+19kHz-116dB-116dB
IMD SMPTE @ 60Hz+7kHz-110dB @ SMPTE4:1
-115dB @ SMPTE1:1
-110dB @ SMPTE4:1
-116dB @ SMPTE1:1
Input sensitivity60Vrms @ G=L
12.6Vrms @ G=M
2.7Vrms @ G=H
12.7Vrms @ G=L
12.7Vrms @ G=M
2.7Vrms @ G=H
Gain-14dB @ G=L
0dB @ G=M
14dB @ G=H
-14dB @ G=L
0dB @ G=M
14dB @ G=H
Output impedance< 0.1Ω< 0.1Ω
Output power2x 6000mW @ 16Ω, THD+N < 0.1%
2x 5500mW @ 32Ω THD+N < 0.1%
2x 840mW @ 300Ω, THD+N < 0.1%
Dimensions174x138x45mm
Net weight870g
Package1x Topping A30 Pro
1x Power cable
InputXLR
OutputJack 6.35mm
OutputJack 4.4mm
3 reviews
Une merveille
Que ce soit sur un dac TDA1541WW Nakamichi DAC101 ou sur un Sabre ESS9018 Breeze modifié, câbles Isoda 08, casque Sony MDR CD3000, cet ampli est non seulement d'une puissance extreme mais aussi d'une transparence et d'un silence sans égal.
Quelles que soient les modifications en amont il les restitue immédiatement avec naturel et richesse de timbre, dynamique sans faille et image sonore ultra précise.
This review has been posted for TOPPING A30 PRO Headphone Amplifier NFCA Black
A little monster.
Little in size, But a giant in sound.
Drives all my headphones without any problems, even the more difficult with high impedance
The price is unbelievable, considering the quality of the amplifier.
It's not my only headphone amplifier, but it's become a favorite..
Véritable 'pépite'...
Ce 'petit' Ampli-Casques est tout simplement sensationnel !
En effet, pour son prix modeste, et en dessous des 800 à 1000 eur, impossible de trouver un ampli capable de 'pousser' mon AKG 340 qui est monstrueusement gourmant en puissance avec ses 2 x 400 Ohms !
Non seulement il arrive à bien 'driver' l'ogre 340 mais en plus la qualité sonore est au Rendez-Vous ! (DAC à 2700 eur en amont tout de même !).
Donc, avec une bonne source vous aurez un grand plaisir d'écoute de TOUS types de casques (3 niveaux de gain) pour un budget abordable. Merci AUDIOPHONICS pour vos produits 'miracles' abordables.
 (3)
The Topping A30 Pro is a high quality NFCA headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at...
