MINIDSP ADEPT ADC Phono Preamplifier with DSP
miniDSP ADept is an ADC with phono preamplifier and DSP. It is based on an XMOS interface and an ESS ES9842 Pro conversion chip. This enables it to convert analog signals up to PCM 32bit 192kHz. Inputs include a balanced XLR analog input and an RCA analog input. Outputs include a Toslink optical output, a coaxial output and a USB-C output. The latter enables the digitized signal to be recorded via a computer.
By buying this product you get 39 loyalty points
Reference : 20264
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 29-05-2026.
miniDSP ADept ADC Phono Preamplifier with DSP 32bit 192kHz
MINIDSP ADept picture
The RCA input also accepts turntables with MM/MC cartridges, thanks to the miniDSP ADept's built-in phono preamplifier. In addition to the standard RIAA equalization curve, the miniDSP ADept offers other equalization curves that will delight vintage vinyl collectors. In addition, input gain, input impedance and input capacitance are adjustable for a very high level of compatibility with various vinyl turntables..
The MINIDSP ADept signal path
miniDSP ADept: a wide range of uses
Line ADC converter
Line ADC converter: this classic configuration allows you to couple any type of analog source to the miniDSP ADept, whether CD, SACD, phono preamplifier, telephone or A/V receiver.
Analog recording
Analog recording: the miniDSP ADept's USB output can be connected directly to a computer. Coupled with the right software, it can record any analog source.
Phono preamplifier
Phono preamplifier: the miniDSP ADept's RCA input accepts vinyl turntables directly, thanks to its ground connector and built-in phono preamplifier.
Vinyl digitizing
Vinyl digitizing: whether used with or without a preamplifier, the MINIDSP ADept can digitize your vinyl records thanks to its USB output and appropriate software.
miniDSP ADept overview
MINIDSP ADept overview
1Phono GND
212V DC power supply
3RCA line/phono input
4Balanced XLR input
5Coaxial output
6Toslink optical output
7USB-C output
MINIDSP ADEPT test by Audio Science Review (Amir)
If you just need a digitizer and already have a DAC, Adept provides an excellent solution with very low noise and distortion. For RIAA equalization and LP ripping, you have perfect equalization but headroom is not great. So be sure to clean your LPs before capturing.
I am happy to recommend the Minidsp Adept phono preamp and capture "card." It is excellently engineered while having a reasonably low cost.
Logo ASR
Product typeADC converter
ADC chipES9042Pro
USB interfaceXMOS UAC2 Asynchronous Processor
Inputs1x RCA line/phono input
1x Balanced XLR input
Outputs1x Coaxial output
1x Toslink optical output
1x USB-C output
Sample rates32bit 192kHz
Filter technology / PresetsIIR / Up to 4 presets
audio Specifications
Input sourceMC (RCA)MM (RCA)Line in RCALine in XLR
Selectable Phono Equalization mode (mode IIR+FIR)RIAA, IEC No.98 (500R-13.7)
Decca 33.3, London M33 (500C-12)
Columbia LP M33 (500C-16)
N/AN/A
Phono EQ Accuracy
(RIAA, Decca and Columbia)
Within ± 0,1dB (20Hz - 20 kHz)
Optional High Pass Filter
(Subsonic filter)
At 20Hz with 24dB/octave
Maximum analog input (before digital gain & RIAA EQ if applicable, at Low, Medium, High Gain)81mV, 29mV, 12mV220mV, 110mV, 68mVN/A, 2.2V, 1.1VN/A, 4.4V, 2.2V
Maximum recommended cartridge output @1kHz, 5cm/sec (Low, Medium, High Gain)4.2mV, 1.5mV, 0.6mV13mV, 6.5mV, 4mVN/AN/A
Selectable Input Impedance
(Low, Medium, High)
50Ω, 100Ω, 1kΩ33kΩ, 50kΩ, 100kΩ33kΩ, 50kΩ, 100kΩFixed at 200kΩ
Selectable Input Capacitance
(Low, Medium, High)
1nF, 3nF, 5nF50pF, 100pF, 500pF50pF, 100pF, 500pFFixed at 100pF
Frequency response20Hz – 20kHz ±0.2dB20Hz – 20kHz ±0.1dB20Hz – 20kHz ±0.05dB
SNR vs Low(L), Medium(M), High(H)
réglage du gain
With RIAA EQ
84dB(A) ref @ 2mV (L)
79dB(A) ref @ 1mV (M)
73dB(A) ref @ 0.5mV (H)
With RIAA EQ
95dB(A) ref @ 10mV (L)
90dB(A) ref @ 5mV (M)
87dB(A) ref @ 2.5mV (H)
122dB(A) at med gain
120dB(A) at high gain
123dB(A) at med gain
122dB(A) at high gain
SNR vs Low(L), Medium(M), High(H) gain settingWith RIAA EQ
-77dB (0.014%) ref @(L)
-71dB (0.028%) ref @(M)
-65dB (0.056%) ref @(H)
With RIAA EQ
-89dB (0.0035%)ref @(L)
-83 dB (0.007%) ref @(M)
-80dB (0.01%) ref @ (H)
-116dB (0.00017%) at med gain
-115dB (0.0002%) at high gain
-117dB (0.00015%) at med gain
-116dB (0.00017%) at high gain
Crosstalk-85dB-100dB-132dB-138dB
Power supply112V DC
Power consumption6W (idle) / 0.9W (standby)
Dimensions150 x 180 x 41mm
Package1x miniDSP ADept
1x Remote control
1x USB cable 1m
1x Toslink modulation cable
1x Power adapter EU 12V 1.6A
InputXLR
InputPhono
OutputOptical Toslink
OutputUSB
OutputCoaxial SPDIF
DAC / ADC ChipES9842Pro
Max sampling rate192kHz
ClassN/A
Remote ControlYes
4 reviews
Bien en numérisation phono mm/mc
Parfait pour mon usage: numérisation des disques vinyles.
Livraison Audiophonics parfaite.
Permet de numériser également d'autres sources analogiques, du coup très versatile.
C'est un périphérique audio ADC de bonne facture.
Parfait avec Audacity et Ableton Live lite
This review has been posted for MINIDSP ADEPT ADC ES9842 Phono Preamplifier with DSP 32bit 192kHz
ADC complet, transparent, unique pour upgrader à petit prix.
J’utilise le MiniDSP Adept pour le studio sous Cubase 14 en 24/88,2 via Toslink, avec ma vieille carte son RME AIO version 1.0 (PCIe), qui reste dans le top‑10 niveau latence et charge CPU/VSTs. La latence supplémentaire est nulle, puisque le signal passe plus court que le tampon ASIO.
Ne pouvant pas investir dans une RME ADI‑2 Pro FS à 1700 €, ce petit module, de la taille d’un Roland Sound Canvas 55, me permet de connecter en XLR mes préamps et DI (comme l’Avalon U5). Je peux même enregistrer via RCA des signaux vintage, comme le Chisound AY d’un Amstrad CPC, en stéréo à 192 kHz (gain = H).
La qualité de prise semble meilleure qu’avec une carte son de 17 ans. Je ne l’ai pas encore utilisé dans une vraie session complète, mais les transitoires me paraissent très précis, ce que je considère plus important que la linéarité pure. De toute façon, il n’existe pas d’autre solution abordable : au‑dessus, il faut compter trois fois le prix, et j’ai cherché un an une alternative d’occasion, sans succès.
Bien pensé
produit bien pensé, dans la tradition minidsp. Idéal pour alimenter un filtre nanodigi ou autre de la marque.Préamp MC et MM paramètrables à souhait, convertisseur AD performant . alimentation séparée, déjà upgradée avec une LHY 12v faible bruit. Avec une écoute musicale, vivante et naturelle qui met en valeur une petite ortofon quintet blue installée sur une Transrotor zet 1, à merveille !
Using it with Audacity on Linux to transfer from MD. Care to be taken to have project sample rate matching the source, and the system not loaded with other tasks during recording.
miniDSP ADept is an ADC with phono preamplifier and DSP. It is based on an XMOS interface and an ESS ES9842 Pro conversion chip. This enables it to...
