CANARE L-5.5CUHD ULTRA COAX Coaxial Cable 12G-SDI Ultra Low Loss 75 Ohm Shielded High Ø7.7mm
This coaxial cable 75Ω L-5.5CUHD, designed and manufactured in Japan by the firm Canare is the assurance of a very high quality product formerly reserved for the professional market.
Reference : 12956
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 12-11-2026.
This cable is sold by the meter. Add X units to the list to receive a cable with a length of X meters.
CANARE L-5.5CUHD
Coaxial Cable 12G-SDI Ultra Low Loss 75 Ohm Shielded High Performances Ø 7.7mm
CANARE L-5.5CUHD Câble Coaxial Ultra Faible Perte 75Ω Blindé Hautes Performances Ø 7.7mm
This cable has excellent electrical and mechanical characteristics, allowing it to ensure an ultra low loss rate. For mounting, we recommend using Canare BNC connectors BCP-D55UHD, specially designed for this cable.
Canare L-5.5CUHD Câble Coaxial 12G SDI
12G-SDI Cable : An exceptional transmission speed
The 12G-SDI cables have been specially developed for the transmission and acquisition of 4K and UHD video streams in 60fps. These cables thus ensure a signal transmission speed of 12Gbps while being less heavy and cumbersome than 4 cables 3G-SDI.
Less loss for greater transmission distance
The design of this cable allows it to ensure a high transmission distance. If the increase in transfer speed tends to negatively impact the maximum transmission distance of cables, Canare has insisted on combining with this L-5.5CUHD both speed and distance. Thus, where the Canare L-5CFB cable has an already more than honourable transmission distance of 68m, this L-5.5CUHD cable ensures a transmission distance of 102m.
Canare L-5.5CUHD Diagram
Schéma CANARE L-5.5CUHD<
1Outer sheath
2External conductor
3External conductor
4Dielectric (Insulation)
5Internal driver
Cable typeCoaxial cable 12G-SDI
Impedance75Ω
Internal conductor section16AWG (1.31mm²)
Internal conductor diameter1.35mm
Outer diameter7.7mm
Insulation diameter5.55mm
External conductor materialCopper foil
ShieldingCopper foil and Braided tinned copper
Dielectric material (insulating)Multilayer PE foam
Fire resistance standardUL 1666
Internal conductor resistance12.8 Ohm/km
External conductor resistance10.3 Ohm/km
Static capacity52 pF/m
Attenuation39.1 dB/100m @6GHz
Diameter (mm)7.7
Length (m)Sold by length
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)1.31
Ground / ShieldingYes
This coaxial cable 75Ω L-5.5CUHD, designed and manufactured in Japan by the firm Canare is the assurance of a very high quality product formerly...
