Produit conforme au descriptif, délivrant un son de très bonne qualité, et des combinaisons d'entrée et de sortie multiples.
This compact digital interface converts a SPDIF coaxial signal to Toslink optical and vice versa. What's more, it integrates an RCA output and a 3.5mm headphone output, capable of driving headphones with impedances from 16 to 300Ω. All outputs operate simultaneously. A potentiometer is used both to switch on the interface (powered by 5V via DC jack) and to control the volume of the analog outputs.
1 | Potentiometer |
2 | Toslink optical input |
3 | Input switch |
4 | Coaxial input |
5 | 5V DC power supply via DC jack |
6 | Jack 3.5mm headphones output |
7 | Stereo RCA output |
8 | Toslink optical output |
Product type | Optical / Coaxial converter DAC Headphone amplifier |
Inputs | 1x Optical Toslink 1x Coaxial |
Outputs | 1x Optical Toslink 1x Coaxial 1x Stereo RCA 1x Jack 3.5mm headphone output |
Supported sampling rates | PCM up to 24bit 192kHz |
Headphones output power | 200mW @ 16Ω 20mw @ 300Ω |
Recommended headphones impedance | 16-300 ohms |
Distortion | < 0.01% (10mW) |
Frequency response | 10Hz - 48kHz |
Power supply | 5V DC 500mA via jack DC (power adapter sold separately) |
Power consumption | 0.5W (max) |
Dimensions | 93 x 83 x 27mm |
Weight | 118g |
Package | 1x Digital interface converter / DAC / Headphones amplifier 1x USB-A to Jack DC cable |
Input | Optical |
Input | SPDIF |
Output | Optical Toslink |
Output | Jack 3.5mm |
Output | RCA |
Output | Coaxial SPDIF |
Max sampling rate | 192kHz |
Color | Black |
Interface chip | NC |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Philippe B.
