IFI AUDIO SILENT POWER OMNI USB USB Conditioner
New
The iFi Audio OMNI USB is a USB conditioner designed to limit the spread of electrical noise between the devices of a digital audio system. A conventional USB hub can pass on to other equipment the interference generated by each connected device; the OMNI USB addresses this problem upstream by physically separating the incoming signal from the outputs.
By buying this product you get 89 loyalty points
Reference : 22709
899,00 €tax incl.
749,17 € tax excl.
iFi Audio Silent Power OMNI USB USB Conditioner
iFi Audio OMNI USB: Front view
The supplied USB OptiLink module converts the received data into a light signal, which is transmitted to the OMNI USB and then converted back into an electrical signal. This optical link blocks interference and stray currents while regenerating the data, in order to preserve its integrity before it is sent to a USB DAC.
iFi Audio OMNI USB: PurePort outputs and noise reduction
Once the signal is isolated, five PurePort outputs take over with Active Noise Cancellation (ANC) technology, designed to reduce residual noise on the USB lines. iFi states it is 100 times more effective than standard noise filters; the aim is to provide a quieter connection to audio devices without altering the transmitted digital data.
Two of the five outputs also provide fully isolated power to USB bus-powered devices. This separation therefore applies both to data transmission and, for compatible equipment, to their power supply, making it possible to place the OMNI USB between a network streamer and a DAC while limiting the interference carried by USB connections.
iFi Audio OMNI USB: Standalone power and battery management
As mains power can be a source of noise in an audio system, the OMNI USB can run on its internal 8000mAh battery. This allows the connection to the mains to be cut for several hours, so the USB outputs can be used without relying directly on a mains power supply during listening.
Smart battery management adapts the charge cycles and keeps the level between 20 and 80%, a range intended to preserve its lifespan. The OMNI USB can thus support long listening sessions without requiring a continuous mains power supply.
iFi Audio OMNI USB: Display and port diagnostics
Its high-definition color TFT screen makes visible operating parameters that are usually difficult to monitor on a USB hub or filter. It monitors power supply noise for each port, including the PurePort outputs, allowing the action of the ANC processing to be followed in real time.
The display also shows the voltage, current and power consumed on each available USB port. This data makes it easier to monitor connected devices and to identify their power requirements more precisely within the system.
iFi Audio OMNI USB: Screen
iFi Audio OMNI USB: Digital conversion and connectivity
Beyond USB filtering, the OMNI USB features digital-to-digital conversion up to 192kHz 24 bits. This function makes it possible to connect a computer, phone or streamer to an older DAC with only an S/PDIF input, without having to replace it to use it with a USB source.
Two coaxial outputs are available, with high and low voltage levels to suit the inputs of different DACs. The device also supports PD 3.0 fast charging of the connected source, keeping a phone powered while in use.
iFi Audio OMNI USB: Setup
To integrate it into a system, simply switch on the OMNI USB and place it between the network music streamer and the USB DAC. The signal then passes through the USB OptiLink module and reaches the DAC from one of the PurePort outputs, where optical isolation and active noise reduction help limit the electrical interference carried by the connection.
Technical specifications
Product typeUSB Conditioner
Inputs1x SFP 10G port
1x SFP 1.25G port
1x BNC (Clock)
Outputs2x USB-A (Data and power)
2x USB-A (Power)
2x USB-C
2x Coaxial
1x Optical Toslink
Supported sampling ratesPCM up to 24bit 192kHz
BatteryLithium-Ion 8000mAh
Supply voltage9VDC 6A
15VDC 4.8A
Dimensions214 x 158 x 41mm
Weight1.19kg
Package1x iFi Audio OMNI USB
1x iFi Audio USB OptiLink
1x 15V power adapter
1x LC fiber cable 1m
1x USB-C to USB-C cable 1m
1x USB-C to USB-A cable 1.5m
2x SFP 10G module
2x SFP 1.25G module
InputSFP
InputClock (BNC)
OutputUSB
Max sampling rate192kHz
Interface chipNC
The iFi Audio OMNI USB is a USB conditioner designed to limit the spread of electrical noise between the devices of a digital audio system. A...
