SMSL PO100 2024 USB Interface Black
SMSL unveils its PO100 2024, a digital interface USB to SPDIF coaxial / optical Toslink. This is based on an XMOS XU316 interface and a CK-02 clock circuit, it supports up to PCM 24bit 192kHz and DSD DoP64. The SMSL PO100 2024 can also decode MQA.
Reference : 20395
38,99 €tax incl.
32,49 € tax excl.
Shipping date: 21-04-2026.
SMSL PO100 2024 Interface XMOS XU316 to SPDIF Coaxial / Optical Toslink 24bit 192kHz DSD DoP64 Black
Photo of SMSL PO100 2024
SMSL
 unveils its PO100 2024, a digital interface USB to SPDIF coaxial / optical Toslink. This is based on an XMOS XU316 interface and a CK-02 clock circuit, it supports up to PCM 24bit 192kHz and DSD DoP64. The SMSL PO100 2024 can also decode MQA. Two LED indicators provide quick information on its operating mode. In addition, its form factor makes it easy to transport.
The benefits of SMSL PO100 2024
SMSL PO100 2024: XMOS XU316 USB interface
The SMSL PO100 2024's USB-C input is combined with a third-generation XMOS XU-316 interface to support high-resolution streams. It even supports MQA streams.
XMOS XU-316 USB interface
SMSL PO100 2024 releases
SMSL PO100 2024: Coaxial SPDIF and Toslink optical output
The SMSL PO100 2024 interface's coaxial and optical Toslink outputs are capable of decoding up to PCM 24bit 192kHz and DSD DoP64.
SMSL PO100 2024: CK-02 clock circuit
The clock circuit in the SMSL PO100 2024 interface provides extremely low jitter when processing the audio signal.
CK-02 clock circuit
SMSL PO100 2024: Indicator LEDs
Two LED indicators show the current sampling rate.
MQA LED indicator
  • Green: certified MQA file
  • Blue: MQA studio quality
  • Red: OFS, MQA file unfolded by front-end device
Sampling rate LED indicator
  • Green : 44.1/48kHz
  • Blue : 88.2/96kHz
  • Red : 176.4/192kHz
  • White : DSD DOP64
SMSL PO100 2024 LED indicators
SMSL PO100 2024: A convenient form factor
The form factor of the SMSL PO100 2024 makes it easy to transport and use with a smartphone, for example.
SMSL PO100 2024 form factor
Product typeDigital interface
USB interfaceXMOS XU-316
Input1x USB-C
Output1x Optical Toslink
1x Coaxial
USB compatibilityMAC OSX / Windows 10 and + (without driver)
USB transmissionAsynchronous
Suppoted sample ratesPCM up to 24bit 192kHz
DSD DoP64
MQA
Power supply5V 0.1A
Dimensions45 x 13 x 50mm
Gross weight75g
Package1x SMSL PO100 2024
1x USB-A to USB-C cable
1x USB-C to USB-C cable
OutputOptical Toslink
OutputCoaxial SPDIF
Max sampling rateMQA
Max sampling rateDSD64
Max sampling rate192kHz
Interface chipXMOS XU316
3 reviews
24/32 bit only, no 16bit output
Works perfectly, but keep in mind that there is no 16bit data stream output option which may cause compatibility issues with some old devices.
This review has been posted for SMSL PO100 2024 USB Interface XMOS XU316 to SPDIF Coaxial / Optical Toslink 24bit 192kHz DSD DoP64 Black
wiim ultra now showing 24 bit
Now my wiim ultra shows 24bit and i didn't even have to install any drivers, plug and play
Incredibile rapporto qualità / prezzo
Questo piccolo dispositivo mi ha risolto un grosso problema, essendosi rotto l'ingresso USB type B del mio DAC. Utilizzando l'uscita coassiale, decodifica senza esitazione tutta la gamma di frequenze fino a 192 kHz ed anche i file in DSD64. Promesse mantenute.
SMSL unveils its PO100 2024, a digital interface USB to SPDIF coaxial / optical Toslink. This is based on an XMOS XU316 interface and a CK-02 clock...
