AUDIOPHONICS DAC Sabre ES9023 V2.2 I2S to Analogue 24bit / 192kHz
Audiophonics DAC Sabre ES9023 V2.1 I2S to Analogue 24bit/192kHz
4.7 / 5
Reference : 8396
16,90 €tax incl.
14,08 € tax excl.
Available
Shipping date: 22-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
Converter with an unrivaled price-quality ratio and direct analog outputs, this module is ideal for all DIY designs.
Equipped with the now famous SABRE ES9023 (equipped with our U-SABRE), Ultra low noise "ON" regulator and capacitors OS-CON this DAC will offer you musical sound and rich in micro details.
Its high versatility allows it to be also usable directly at the output of a Raspberry PI via the GPIO.
Features:/ Strong>
  • Input: I2S
  • Output: RCA
  • Supported sampling rates: 16 / 24bit 192 khz
  • This converter has its own clock
  • TCXO full-size clock slot
  • Connection delivered
  • Distance connections: 29cm
  • RCA Distance: 20mm
  • Spacing: 40mm, 32mm
  • PCB Dimensions: 50 x 42mm
Input I2S:
  • Orange: MCLK
  • Yellow: GND
  • White: DATA
  • Red: LRCK
  • Black: BCK
Food :
  • Black: GND
  • Red: + 5V
Can be used with:
https://www.audiophonics.fr/images2/picoreplayer.jpg
PDF manufacturer
https://www.audiophonics.fr/images2/8396/8396_ES9023_I2S_DAC_5.jpg
Illustration of implementation (here on a Raspberry PI equipped with Volumio).
Connection to P5 of Raspberry Pi.
https://www.audiophonics.fr/photos/RASPBERRY/ES9023_RASPBERRYPI.jpg
ComponentES9023
InputI2S
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
9 reviews
DAC d'un très bon rapport qualité/prix
Avec oscillateur interne:
Bonne scène sonore. Des grave percutants et profonds.
Mediums et aigus en retraits. Aigus manquants de variations.
Malgré tout une bonne surprise pour sa musicalité.
Avec oscillateur externe (ian McDualXO avec NDK NZ2520SDA):
Grosse amélioration. La scène sonore prend de l'ampleur, plus de largeur et de profondeur.
Les détails apparaissent. Les voix s'expriment mieux. Les aigus s'affinent mais restent en retrait.
Le point faible de ce DAC se situe sur l'extinction des notes qui ne sont pas très naturelles.
Malgré tout un très bon rapport qualité/prix.
This review has been posted for AUDIOPHONICS DAC Sabre ES9023 V2.2 I2S to Analogue 24bit / 192kHz
Extra !
Son riche et détaillé, aiguës saillants et basses profondes et précises. Attention toutefois dans les extrêmes aux morceaux trop riches, mais rien de grave. (mériterait un Allo Recloker?)
Si ça interesse pour ceux qui ont une imprimante 3D et qui veulent ranimer un vieux raspberry pi model B sous volumio, j'ai modifié un boitier sous tinkercad afin d'intégrer le DAC : https://www.thingiverse.com/thing:2689767
Musicalement votre, et toujours un grand merci à Audiophonics pour cette petite perle :)
Avec l'interface USB LJ CM6631A V 1.3
Câblage entre l’interface USB et le DAC :
DATA -> DATA
GND -> GND
LRCK -> LRCK
SCLK -> BCK
Ne pas connecter MCLK -> MCLK !
Nickel !
DAC de qualité, branché un un vieux Rpi B en I2S avec piCorePlayer avec le schéma de cablage du site (déclaré en Hifiberry), il marche impec !
Attention: les cotes annoncées sont fausses, le modèle reçu mesure 53 mm par 45mm.
Kudos pour audiophonics !
super sur pi A et barre de son de base
utilisé avec RUNE audio, il faut declarer hifiberry en I2S.
je vais en recomander un pour un projet plus hifi
