ESS ES9038Q2M DAC Module I2S 32bit 192khz DSD LT1963 Regulator NJM5532 AOP
This DAC module is equipped with the excellent ES9038Q2M conversion chip, accompanied by high quality components for dynamic and detailed sound reproduction. With an I2S input and RCA and 3.5mm Jack outputs, this DAC supports high sampling rates up to 32bit 192kHz in PCM and DSD256.
Reference : 12704
49,90 €tax incl.
41,58 € tax excl.
DAC ES9038Q2M
I2S to RCA Jack 3.5mm 32bit 192kHz DSD LDO LT1963 NJM5532
Module DAC ESS ESS9038Q2M
DAC ESS ES9038Q2M
This complete DAC module is equipped with an excellent latest generation ESS ES9038Q2M chip. This provides high quality Digital / Analog conversion, providing dynamic and detailed sound. In addition, it supports high sampling rates for the delight of audiophiles, up to 32bit 192kHz in PCM and up to DSD256.
Components serving the sound
The DAC is here supported by components of very good quality. Note the presence of a low noise OPA NJM5532DD on DIP8, two LM317T voltage regulators and an LDO LT1963 for a stable current, a 100Mhz clock to lower the jitter and excellent ELNA filter capacitors. What ensure a sound reproduction of high quality.
The OPA being mounted on DIP8 it can be replaced by you by a more efficient model, such as theOPA1622.
Simple but effective connectivity
This ES9038Q2M module offers an I2S (5 pins, Cable supplied) input, a resolutely audiophile protocol separating clocks from data and providing the signal with a short path. In output, one will find simply a Stereo RCA and a Jack 3.5mm.
DACESS ES9038Q2M
Regulators / LDO2x LM317T
1x LT1963
OPA (DIP8)NJM5532DD
Clock100Mhz
DNR129dB
THD+N-120dB
Sampling ratePCM : up to 32bit 192kHz
DSD256
Connectors
InputI2S (5 pins : GND, MCK, LRCK, BCK, DATA)
OutputsStereo RCA
Jack 3.5mm
Power supplyAC 15-18V (3 lines) + AC 7-12V (2 lines)
DimensionsRCA Stéréo
Jack 3.5mm
Weight150g
Fixation holes spacing87mm / 83mm
Package1x DAC ES9038Q2M Module
1x 5 pins I2S input connector (Cable supplied)
DAC ESS9038Q2M
  1. Power supply AC 7-12V
  2. Power supply AC 15-18V
  3. 2x LM317T Regulators
  4. LDO LT1963
  5. I2S Input
  6. Clock 100Mhz
  7. DAC ES9038Q2M
  8. AOP NJM 5532DD
  9. RCA Output
  10. Jack 3.5mm Output
InputI2S
OutputJack 3.5mm
This DAC module is equipped with the excellent ES9038Q2M conversion chip, accompanied by high quality components for dynamic and detailed sound...
