The Wondom UCM‑PCM2706C is a stereo USB audio converter of DDC/DAC type designed to transform digital stream from USB interface into S/PDIF, I2S and analogue outputs. It leverages PCM2706C chip to support signals up to 48 kHz, thereby enabling stable conversion directly usable by different audio stages while ensuring native compatibility without driver via USB 2.0 Full Speed interface.
The Wondom UCM‑PCM2706C is a USB to digital and analogue audio converter leveraging Texas Instruments PCM2706C chip, designed to transform USB stream into S/PDIF, I2S and stereo analogue outputs. It supports sampling frequencies of 32, 44.1 and 48 kHz, thereby enabling clean and usable signal restitution while ensuring coherent conversion to different audio interface types, facilitating interconnection between computer sources and Hi‑Fi or professional equipment.
Integration of driverless USB 2.0 Full Speed controller guarantees native compatibility with Windows, Linux and macOS environments, eliminating any software constraint during implementation. This approach extends to use of USB Type‑C port ensuring both power and data transmission, enabling simplified cabling while maintaining stable and immediately operational connection.
The module simultaneously delivers S/PDIF, I2S and analogue outputs, enabling signal adaptation to different audio architectures without additional intermediate conversion. This versatility authorizes direct integration with amplifiers, stereo systems, active speakers or headphones, while guaranteeing signal continuity suited to each input type constraints.
Embedded commands enable volume adjustment or signal muting directly from module, while dedicated ports authorize control relocation to chassis front panel. This control logic completes with selector enabling rapid switching between S/PDIF and I2S output modes, thereby facilitating adaptation to different configurations without complex reconfiguration.
Architecture prioritizes rationalized cabling through single USB Type‑C port combining power and signal, reducing interconnections while limiting error sources. This approach is strengthened by plug-and-play connectors and compact layout with vertical ports and angled connector, enabling facilitated integration in restricted spaces or embedded systems.
CE and FCC certified, the module meets electromagnetic compatibility and safety requirements, guaranteeing compliant operation in both domestic and industrial contexts. This reliability maintains across extended temperature range of -20 °C to 65 °C, ensuring operating stability even in constrained environments or those subject to significant thermal variations.
| Specifications | |
| Product type | DAC module |
| Inputs | 1x USB-C 1x USB input via PH 4 pin connector |
| Outputs | 1x 3.5mm jack 1x Analogue output via PH 5 pin connector 1x S/PDIF output via PH 4 pin connector 1x I2S output via PH 6 pin connector |
| Output level | Min: 0.585Vrms Typ: 0.650Vrms Max: 0.715Vrms |
| Noise level | Typ: 8.4µVrms Max: 12µVrms |
| Frequency response | 20Hz-20kHz |
| DAC chip | PCM2706C |
| Supported sample rate | PCM 16bit 48kHz |
| Total harmonic distortion plus noise (THD+N) | 0.017% @20Ω 0.029% @32Ω |
| Channel separation | -64dB |
| Signal-to-noise ratio (SNR) | 95dB |
| General | |
| Supply voltage | Min: 4.5V DC Typ: 5V DC Max: 5.5V DC |
| Dimensions | 76.2 x 50.8mm |
| Mounting holes spacing | 69.6 x 44.5mm |
| Weight | 25g |
| Package | Sold individually |
| Input | USB |
| Input | PH 2.0mm |
| Output | Jack 3.5mm |
| Output | PH 2.0mm |
| DAC / ADC Chip | PCM2706C |
| Max sampling rate | 48kHz |
| Interface chip | PCM2706C |
