This small module is an adapter with a stereo RCA input on the one hand, and an XH 2.54mm and PH 2.0mm output on the other hand. It allows to adapt these connectors for easy connections.
| Specifications | |
| Product type | XH / PH to RCA adapter board |
| Input | Stereo RCA |
| Outputs | 1x XH 2.54mm 3 pins 1x PH 2.0mm 3 pins |
| Dimensions | 50 x 23 x 2mm |
| Mounting holes spacing | 39mm |
| Package | 1x Adapter board 1x PH 2.0mm 3 pins 20cm cable |
