ATOHM C150 DCR 08 Speaker Driver Mid-Bass 80W 8 Ohm 88dB 15cm
The Atohm C150 DCR mid-bass driver is designed to deliver top performance in a compact 15cm format. This driver is ideal for use in 2, 2.5 or 3-way speakers, whether bass-reflex or sealed.
Reference : 22026
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 13-11-2026.
ATOHM C150 DCR 08 Mid-bass speaker driver 80W 8 Ohm 88dB Ø15cm
Thumbnail of the ATOHM C150 DCR speaker
Summary of the key benefits of the ATOHM C150 DCR:
  • A lightweight, rigid paper diaphragm for wide bandwidth and high efficiency.
  • Backend processing that ensures optimal high-frequency attenuation and facilitates filter tuning.
  • A wide NBR rubber suspension featuring LDS™ technology, providing progressive damping for a linear response in the midrange.
  • F.E.A. optimized motor with a high, symmetrical and linear force factor.
  • TICR™ technology combines two copper rings positioned on the field plate to maximise the available magnetic flux and improve heat dissipation.
  • Low, linear inductance across a wide excursion range, resulting in very low distortion levels.
  • High-rigidity aluminium reel holder with forced ventilation.
  • Spider M-GUARD™ technology, featuring progressive geometry and low-creep material, provides mechanical « soft-clipping » during the most extreme deflections, thereby ensuring outstanding dynamic performance and enhanced reliability.
  • Reinforced die-cast aluminium salad bowl with a wide opening at the back.
Performance graphs and illustrations of the ATOHM C150 DCR 04 loudspeaker
Speaker typeMid-bass
Nominal diameterØ15cm
Admissible power (RMS)80W
Admissible power (MAX)300W
Impedance8Ω
Sensitivity88dB 2.83V/1m
Voice coil diameterØ25mm
Coil height16.3mm
Air gap height4mm
Recommended cutoff frequency≤4000Hz
Paramètres Thiele & Small
Resonance frequency (fS)49Hz
CC resistance (RE)6.2Ω
Power quality factor (QES)0.62
Mechanical quality factor (QMS)3.1
Overall quality factor (QTS)0.51
Air volume equivalent to the suspension (VAS)11.7L
Coil inductance (LE)0.17mH
Force factor (B·l)6.36 N/A
Moving mass (MMD)12.4g
Membrane area (SD)97.7cm²
Maximum linear travel (Xmax)11mm
Materials
Membrane materialPaper
Suspension materialRubber
Coil materialCopper
Frame materialAluminium
Weight1.04kg
Packaging1x ATOHM C150 DCR 08
Speaker Power (W RMS)80.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)150.0
Diaphragm typePaper
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)11.0
Lowest frequency (Hz)200
Highest frequency (Hz)20000
The Atohm C150 DCR mid-bass driver is designed to deliver top performance in a compact 15cm format. This driver is ideal for use in 2, 2.5 or 3-way...
