AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752 Adjustable 5–24 V
The Audiophonics PSU S4-HP power supply module has been designed to provide a clean DC voltage supply to an amplifier or other audio circuit. Its particularly rigorous design, and the quality of its components, make it an excellent choice for powering a digital amplifier or any other low-voltage high-fidelity component such as certain DAC converters, headphone amplifiers, etc... These are just some of the devices whose performance it helps to improve.
4.9 / 5
Reference : 10435
69,00 €tax incl.
57,50 € tax excl.
Shipping date: 26-05-2026.
Audiophonics PSU HP-S4 Linear Power supply Module DC Micrel29752 Adjustable 5–24V
Audiophonics PSU S4-HP Power supply module
This version is equipped with a 6.5mm-thick pre-drilled aluminum plate to optimize dissipation and therefore power supply capacities. The holes allow you to easily integrate this module into the case of your choice.
It is fitted with a potentiometer and a jumper to adjust the voltage from 5 to 24V from an AC voltage source with a value between 5 and 20V AC respectively.
The Audiophonics PSU S4 uses four Schottky SB2045FCT rectifiers in TO-220 heatsink housings, offering low losses. The voltage regulator is a Micrel MIC29752BWT, an extremely high-performance component thanks to its extremely low dropout (270mV@4A / 425mV@7.5A).
On the filtering side, the module boasts impressive capacity, with 10 electrolytic capacitors of 8100µF / 35V for a total of 81000µF to limit ripple, and therefore the necessary dropout. A 220µF OsCon Low ESR capacitor stabilizes the output.
This design not only provides a highly stable output, but also delivers high currents with low heat dissipation and good linear efficiency. For example, to supply 12V DC 7.5A, an 11.5V AC toroid is sufficient (general dropout only 4.2V). That's around 31W of dissipation for 90W of output.
Schottky rectifiers4x SB2405FCT
Capacitors10x 8100µF 35V
1x 220µF 35V (output filtering)
Voltage regulatorMicrel MIC2975BWT
Discharge resistorIntegrated
Output VoltageAjustable by means of a potentiometer + jumper (Transformer must provide appropriate voltage)
Jumper On: Adjustable from 12 to 24V
Jumper Off: Adjustable from 5 to 12.5V
Output VoltageVariable 5 to 24V
Maximum output currentto 7.5A according to the heatsink
connectable Maximum Music Powerapproximately 150W
Dimensions130 x 60 x 37mm.
Spacings50mm, 120mm
Distances heatsinks bores50mm
Weight204g
Transformer voltage5 to 20V AC.
Exemple : 11 or 12V AC for a 12VDC Output, the transformer must be able to deliver a rectified voltage with a delta of 4 to 6V DC
InputPCB Connector
OutputPCB Connector
Output voltage (V)5.0
Output voltage (V)10.0
Output voltage (V)24.0
Output voltage (V)12.0
Output voltage (V)20.0
Output voltage (V)15.0
Output current (A)7.5
Input voltage (V)N/A
Power SupplyRegulated Linear Power Supply
7 reviews
Très très bonne alimentation
Associée à un trafo toroïdal en cuve Talema 80va elle alimente Mon Keces Ebravo.
C'est parfait et procure une
amélioration évidente comparée à celle d'origine ou même une brique Meanwell qualité médical.
This review has been posted for AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752 Adjustable 5–24 V
elle vient remplacer trois modules à base de LT 1084 avec un condo 4700 µf qui alimentait deux PC dédiés (serveur Roon et lecteur Roon sous fédora ccrma avec 35 et 10 W de tpd)
Pour à peine plus chère, la différence est bluffante.
Les basses sont plus tendues, les timbres et la dynamique sont à l'avenant, les détails ressortent mieux.
Meilleur silence de fond.
C'est clair que l'alimentation est la clef de la qualité audio.
Qualité remarquable
Je l'utilise pour alimenter en 24V un ampli casque à lampes avec en amont une module SPMS calé sur 25.5V. Cela donne d'excellent résultats en terme de qualité sonore. Très satisfait.
alimentation linéaire
j'utilise cette alimentation pour alimenter un l streamer de réseau de haut performance (3DLAB.nanoplayer).en remplacement de l'alim d'origine (un vulgaire boitier 220v/9v, polluant à fond..!.
le résultat est saisissant , lors d'une écoute "audiophile". (j'ai une installation avec un ampli a tube 845, et des baffles en supravox, de conception maison.) . SUPER RESULTAT. bravo.
 (4)
Utilisée pour alimenter une carte mère sous Daphile (CPU de 10w de TDP).
Dimensionner impérativement le radiateur en fonction de la consommation, stabilité parfaite du voltage de sortie. A l'écoute, très supérieure aux cartes avec régulateur LT1083, différence de prix importante mais justifiée.
The Audiophonics PSU S4-HP power supply module has been designed to provide a clean DC voltage supply to an amplifier or other audio circuit. Its...
