DSPEAKER ANTI-MODE X2D DSP
Compact yet extremely powerful, the DSPeaker Anti-Mode X2D presents itself as a DSP to perform acoustic correction and equalization tasks with great efficiency. It features the brand-new Anti-Mode™ 3 algorithm, capable of automatically optimizing your main speakers and optional subwoofer according to your acoustic environment. This makes it quick and easy to improve the sound quality of an existing HiFi system.
By buying this product you get 62 loyalty points
Reference : 18502
625,00 €tax incl.
520,83 € tax excl.
Shipping date: 08-07-2025.
Acoustic Correction and Equalizer
DSPEAKER ANTI-MODE X2D DSP Acoustic Correction and Equalizer
A fully customizable tone control feature is also available, in addition to a state-of-the-art digital crossover and subsonic filter. Most features can be adjusted in real time using the supplied remote control. Several sound profiles are also available, allowing quick access to previously saved settings.
High-performance acoustic correction
DSPeaker Anti-Mode X2D offers a high-performance acoustic correction system to limit or even cancel out the impact of the many defects that a listening room can present on the quality of reproduction of an audio system. It uses a microphone-based calibration system to resolve problems such as reverberation, echo, sound reflection and speaker/subwoofer mismatch, so that your audio system can really shine. This correction is fully automatic and transparent.
Tone control
In addition to its acoustic correction function, the DSPeaker Anti-Mode X2D provides tone control, allowing you to manually adjust the level of bass, midrange and treble. These parameters can be stored in three sound profiles, which can be accessed at any time.
Easy integration
The DSPeaker Anti-Mode X2D is placed directly between your sources and your DAC and active subwoofer. The DSPeaker Anti-Mode X2D is designed for this purpose, with a combined RCA stereo/coaxial input, a Toslink optical input and a USB-C port. Thanks to its integrated DAC, the digital section supports audio streams up to PCM 24bit 192kHz. Outputs include a Toslink optical output, a coaxial SPDIF output and a subwoofer output.
112VDC power supply connector
2USB-A input (for firmware update)
3USB-C audio input
4Toslink optical output
5SPDIF coaxial output
6Subwoofer output
7Stereo RCA input / Coaxial SPDIF input
8Toslink optical input
Product typeDSP Acoustic correction
Inputs1x Combo RCA Stereo / SPDIF Coaxial
1x Optical Toslink
1x USB-C
1x USB Audio 1.0 Stereo PCM
1x Microphone input
Outputs1x Optical Toslink
1x SPDIF Coaxial
1x Subwoofer output (RCA)
Supported sample ratesUSB: PCM up to 24bit 96kHz
SPDIF: PCM up to 24bit 192kHz
Frequency range (analog to analog)5Hz - 22kHz
Analog input level2.3Vrms (max)
SNR analog input107dB
THD (-6dB) analog input< 0.002%
Optical/SPDIF output24/bit 96kHz
Sbwoofer output level2.3Vrms (max)
SNR subwoofer output100dB
THD (-6dB) subwoofer output< 0.03%
Supply voltage12VDC 2.6A
Dimensions126 x 80 x28mm
Consumption1.5W
Standby power consumption0.1W
Dimensions (L*P*H)126*80*28mm
Weight300g
Package1* DSPeaker Anti-Mode X2D
1* Measurement microphone
1* Remote control
1* Power supply
OutputSubwoofer
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate192kHz
Compact yet extremely powerful, the DSPeaker Anti-Mode X2D presents itself as a DSP to perform acoustic correction and...
