Interface DAC DSP Processor SHARC ADSP21489 Dirac Live
The MiniDSP DDRC-24 is the most compact Dirac Live and DAC processor in the range, allowing you to enjoy the excellent acoustic correction solution without the hassle of a large device.
Powered by a 400MHz Analog Devices SHARC processor, the DDRC-24 features 4 channels of outputs, allowing for example the integration of a subwoofer or stereo system associated with the Dirac Live system. Dirac Live allows access to numerous parameters such as a mixing matrix or crossover filters via an easy to use interface. Inputs include stereo RCA, Toslink Optical, and Mini USB (XMOS), both of which are connected to a DAC that supports PCM sample rates up to 192kHz.
The DDRC-24 comes with a Dirac Live license and can also be used with the Room EQ Wizard software to perform measurements prior to the Dirac calibration if required.
The UMIK-1 microphone is not supplied with this product. It can be purchased separately (see accessories) to perform acoustic measurements using the Dirac Live software.
| Specifications | |
| Product type | DSP |
| DSP Chip | Analog Devices SHARC ADSP21489 32bit floating point 400Mhz |
| Internal processing resolution and sample rate | 32bit / 48kHz |
| DAC resolution | 24bit |
| Inputs | 1x Unbalanced stereo RCA 1x Optical Toslink 1x Mini USB (ASRC : 20Hz - 216kHz) |
| Outputs | 2x Unbalanced stereo RCA |
| USB Interface | XMOS Xcore200 |
| Input levels | 2Vrms / 4Vrms (switchable) |
| Output level | 2Vrms |
| Input impedance | 10kΩ |
| Output impedance | 560kΩ |
| Calibration software | Plugin DDRC-24 |
| Filtering technology | Dirac Live |
| DSP presets | Up to 4 presets |
| Impulse response correction | |
| Infrared remote learning | |
| Compatibility | Windows Mac |
| Bass management | |
| Room EQ Wizard support | |
| General | |
| Dimensions | 119 x 107 x 27mm |
| Power supply | 12VDC 2.5mm via Jack DC 2.1mm |
| Case material | Aluminium |
| Color | Black |
| Package | 1x MiniDSP DDRC-24 1x Dirac Live license 1x Power supply 12V 1x USB cable 1x Plugin for DSP control |
