MINIDSP MCHSTREAMER Box Interface USB XMOS to ADAT / Optical 24bit 192kHz
The MiniDSP MCH Streamer Box is an asynchronous multi-channel USB to Toslink/ADAT interface. It incorporates a high-quality XMOS Xcore 200 USB interface chip to ensure excellent sound reproduction. The USB 2.0 standard gives this interface high performance for multichannel playback and recording.
4.0 / 5
Reference : 18843
169,00 €tax incl.
140,83 € tax excl.
Shipping date: 05-05-2026.
MiniDSP MCHStreamer Box Interface USB XMOS to ADAT / Optical 24bit 192kHz
MCH Streamer Box picture
The MiniDSP MCH Streamer Box is an asynchronous multi-channel USB to Toslink/ADAT interface. It incorporates a high-quality XMOS Xcore 200 USB interface chip to ensure excellent sound reproduction. The USB 2.0 standard gives this interface high performance for multichannel playback and recording. Using one of the supplied MiniDSP firmware packages, the MHC Streamer Box is able to switch between ADAT and Toslink signals. In addition, this device works plug-and-play thanks to native Mac OS and Linux (Alsa) drivers. For Windows, however, an ASIO/WDM driver is required.
Photo of MHC Streamer Box Toslink inputs/outputs
Product typeUSB to ADAT / Optical Toslink interface
USB interface chipXMOS Xcore 200
CompatibilityWindows
Mac
Linux 2.0
Android
iOS (with camera kit)
Sampling rates supported on optical input/outputToslink: stereo support up to 44.1/48/88.2/96/176.4/192 kHz
ADAT: 8-channel ADAT mode at 48/44.1 kHz and 4-channel ADAT mode at 96 kHz
AlimentationVia USB
Dimensions24 x 64 x 67mm
Package1x MCH Streamer Box
1x USB cable 1m
2x Optical Toslink cable
OutputOptical Toslink
Max sampling rate192kHz
Max sampling rate48kHz
Max sampling rate96kHz
Max sampling rate44.1kHz
ColorSilver
Je m'en sers pour connecter un iPad à une carte son installée sur un PC, via les connecteurs ADAT.
Bien que le manuel indique que la carte est conçu pour n'être utilisée que comme maître de synchro, il y a un réglage pour la mettre esclave dans le logiciel de configuration Windows, et les réglages exposés à Alsa sous Linux. Elle fonctionne très bien dans ce mode.
Par contre aucun moyen de régler ça depuis un iPad, et les réglages ne sont pas sauvés dans une mémoire persistante. Donc la carte retourne au réglage comme maître si elle n'est plus alimenté.
Si vous voulez qu'elle soit en esclave sur un iPad (dans mon cas parce que l'horloge de ma carte son est bien meilleure), il y a moyen de contourner ce problème : si on utilise un hub USB alimenté par le secteur, elle continue à être alimentée même si aucun hôte n'est connecté au hub. On peut donc débrancher le hub de l'iPad, pour le connecter à un PC, mettre la carte en esclave depuis le PC, et rebrancher le hub sur l'iPad. Tant que ça reste alimenté pendant la manip, le réglage devrait rester.
C'est un peu dommage que le constructeur ne propose pas de version du firmware qui se comporte en esclave par défaut, mais étant donné que le manuel spécifie qu'elle n'est conçue que pour être utilisée en maître de synchro je ne vais pas me plaindre. Ça reste le moyen le plus bon marché que j'ai trouvé pour remplir le rôle que je voulais.
This review has been posted for MINIDSP MCHSTREAMER Interface USB XMOS to ADAT / Optical 24bit 192kHz
The MiniDSP MCH Streamer Box is an asynchronous multi-channel USB to Toslink/ADAT interface. It incorporates a high-quality XMOS Xcore 200 USB...
