MiniDSP DDRC-22A 24/96kHz Stereo Analog Dirac Live with UMIK-1
4.0 / 5
By buying this product you get 94 loyalty points
Reference : 9039
949,00 €tax incl.
790,83 € tax excl.
The Dirac DDRC-22A fits between your analog source and your integrated preamplifier or amplifier.
It has been designed to radically transform your listening and allow you to rediscover your audio installation.
MiniDSP and Dirac Live research brings you an acoustic processing and digital correction solution with this unique hardware / software combination.
The processor incorporates a sophisticated digital processing algorithm that intelligently corrects frequency and time errors caused not only by the listening room but also by those present themselves.
Inresults in an improved stereo image, more clarity and realism, a more precise timbre and a deeper bass.
Voiso the product you need. Correct the acoustics of your listening room with an easy to use interface.
The housing is composed of a high-resolution 24-bit / 96kHz audio processor.
You have a Umik-1 measuring microphone with its own calibration system.
Thus, you get excellent results.
This product is compatible with our remote control: ref 10901.
Specifications:
  • Processor: 32bit
  • Resolution ADC / DAC: 24bits / 96kHz
  • Frequencyinternal sampling: 96kHz
  • Signal to noise ratio: 114dB
  • Input Impedance: 40k Ω
  • Input level max. : 2Vrms or 8Vrms
  • Output impedance: 560 Ω
  • Output Level: 2Vrms
Physical characteristics:
  • Dimensions (in mm): 210 x 205 x 40
  • Weight: 3.2kg
Includes: 1 USB cable A / B, 1 tripod, 1 microphone, 1 power supply 5V 2A, 2 brackets for fixing
Compatibility: Microsoft Windows Vista SP1 / XP Pro SP2 / Win7 / Win8
Intel Pentium III min., AMD Athlon XP (SSE required), 2GB RAM, 2 USB Type-A ports
MiniDSP Dirac Getting Started - Click Here
Software modeling of sound recording for acoustic processing
Schéma pièce d'écoute
Pre / post response curve
Onde de fréquence avant / après
Software InterfaceDirac Livespectrum correction
Réglage du spectre
De la correction acoustique à la portée de tous
Utilisateur de ce produit depuis quelques semaines et plutot satisfait, des résultats mais aussi de la facilité d'utilisation. Un petit regret, l'alientation un peu cheap, bien que je n'ai pas noté de dégradation du signal et aussi l'inversion droite/gauche des XLR
This review has been posted for MiniDSP DDRC-22A 24/96kHz Stereo Analog Dirac Live with UMIK-1
