DAYTON AUDIO AXIS-8 8-Channel DSP
New
The Dayton Audio AXIS-8 is a four-input, eight-output DSP controller designed to configure audio systems in the car or at home, from active speakers to multi-way installations. Its guided software assists with setting up routing, filters and equalization, making digital processing accessible while retaining advanced tuning tools.
By buying this product you get 54 loyalty points
Reference : 22675
549,00 €tax incl.
457,50 € tax excl.
Dayton Audio AXIS-8 8-Channel DSP
DAYTON AUDIO AXIS-8: Front view
The Dayton Audio AXIS-8 is a DSP controller with four inputs and eight outputs designed to configure audio systems in the car or at home, from active speakers to multi-way installations. Its guided software assists with setting up routing, filters and equalization, making digital processing accessible while retaining advanced tuning tools.
Its analog and digital inputs make it easy to integrate with a variety of sources, while control from a mobile device lets you adjust the system from the listening position. Combined with its bass correction and protection functions, the AXIS-8 centralizes the configuration and evolution of an audio installation, from initial setup to more detailed adjustments.
Dayton Audio AXIS-8: 4-input / 8-output DSP controller
The Dayton Audio AXIS-8 is a DSP controller designed to configure and expand audio installations in the car or at home, from systems with a subwoofer to active multi-way speakers. Its four inputs and eight outputs allow the signal to be distributed among several speakers and their operation to be adjusted separately, while its analog and digital connectivity makes it easy to integrate with a variety of sources and equipment. Its guided software makes digital processing accessible to beginners without limiting advanced tuning options.
DAYTON AUDIO AXIS-8: Control interface
DAYTON AUDIO AXIS-8: Tuning assistance
Dayton Audio AXIS-8: Setup wizard and built-in guides
The setup wizard guides you through getting started step by step and offers templates suited to several automotive and home applications. Simply enter the inputs, outputs, routing and tuning goals to obtain an initial working configuration, which can then be refined according to the system. Guided tours present the menus and tools, while dedicated instructions assist with setting up functions such as time alignment, limiters or subwoofer configuration.
Tooltips explain functions and parameters directly in the interface, helping you understand the controls without interrupting your work to consult a manual. The "Check My Setup" function examines the configuration and flags potential problems before continuing with adjustments. The software can, for example, warn of an inconsistent crossover point, a tweeter without a high-pass filter or a bass boost likely to damage a speaker.
Dayton Audio AXIS-8: Filter design and parametric equalization
The visual filter designer divides the spectrum between subwoofer, woofer, midrange and tweeter by assigning high-pass and low-pass filters to each output. This organization lets you start from a simple configuration with a subwoofer and main speakers, then move to an active multi-way system while keeping a clear view of each driver's role. Visual warnings flag certain settings that appear too low or incompatible with the rest of the configuration.
The parametric equalizer allows each band to be adjusted by center frequency, correction level and Q factor, which determines the width of the band concerned. Broad corrections are used to modify the overall tonal balance, while narrower filters can target specific resonances with less effect on neighboring frequencies. Combined with the DSP's measurement and tuning tools, these parameters allow you to move from general correction to more detailed fine-tuning.
DAYTON AUDIO AXIS-8: Filtering
Dayton Audio AXIS-8: Voltage level compatibility
Audio devices can transmit signals at very different levels, even when they use the same RCA connector. Input and output range selectors allow the AXIS-8 levels to be matched to the connected equipment and limit the risk of input overload. The controller can also act as a preamplifier to boost a low-level signal intended for a less sensitive device, notably some car amplifiers.
Dayton Audio AXIS-8: Connectivity and system integration
The analog line-level and high-level inputs allow the AXIS-8 to be connected to aftermarket sources as well as factory audio systems. Bluetooth, optical and USB-compatible inputs extend this integration to digital sources, so the controller can sit at the heart of an existing installation or a custom multichannel project. The four-input, eight-output configuration offers the flexibility needed to distribute the signal and apply separate processing to the different channels.
Dayton Audio AXIS-8: Automatic bass equalization and remote control
With the CALMIC measurement microphone sold separately, the Bass Auto-EQ function measures the bass response of the installation and its listening environment, then identifies peaks and dips to apply corrections automatically. This equalization provides a starting point for smoothing the low-frequency response, which the user can then refine to their preferences. The AXIS-R wired remote, also optional, provides access to volume and presets without opening the software.
DAYTON AUDIO AXIS-8: EQ
Dayton Audio AXIS-8: Bass processing and protection
The Dynamic Bass function adapts the bass boost to the signal level: it can reinforce the bass at low volume, then reduce this boost as the level increases, maintaining bass presence without straining the system as much at high volume. Super Bass relies on psychoacoustic principles to generate higher harmonics from low frequencies, giving the perception of deeper extension than the speaker can reproduce directly.
Adjustable limiters protect speakers and amplifiers by keeping the signal below a user-defined threshold. When this threshold is reached, the DSP automatically reduces the gain, helping to control the output level during sustained listening.
DAYTON AUDIO AXIS-8: Bass processing
Dayton Audio AXIS-8: Adjustments from a mobile device
From a compatible phone or tablet, the user can access the main DSP parameters without staying in front of a computer. Routing, filters, equalization, levels, delays and presets can be adjusted from the listening position, making it easier to evaluate changes immediately and fine-tune in real time, in a car as well as in a listening room.
DAYTON AUDIO AXIS-8: Mobile interface
Technical specifications
Product typeDSP
Input4x RCA
1x 3.5mm jack (mic)
1x Molex
1x Toslink optical
1x USB-C
1x Wired remote port
Bluetooth
Output8x RCA
Frequency response5Hz-22kHz
Supported sampling ratesPCM up to 24bit 48kHz
Total harmonic distortion more noise (THD+N)0.008%
Signal-to-noise ratio (SNR)103dB
Number of storable presets6
DSP chipsADSP-21479 SHARC
ADAU1701 SigmaDSP
Dimensions200 x 115 x 51mm
Weight730g
Package1x Dayton Audio AXIS-8
1x Power adapter
1x Bluetooth antenna
1x Rack mounting kit
InputMolex
InputJack 3.5mm
Max sampling rate48kHz
The Dayton Audio AXIS-8 is a four-input, eight-output DSP controller designed to configure audio systems in the car or at home, from active...
