MiniDSP OpenDRC-DA8 Audio Digital Processor DSP 32bit S/PDIF RCA
MiniDSP OpenDRC-DA8 Audio Digital Processor DSP S/PDIF RCA
Reference : 12226
469,00 €tax incl.
390,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
MiniDSP OpenDRC-DA8 DSP Digital Audio Processor with Digital Sound Correction
The openDRC-DA8 from MiniDSP is a multi-channel audio processor with floating point DSP at an affordable price. Powered by an Analog Devices Sharp ADSP21369 processor, the OpenDRC-DA8 engine enables complex processing such as digital room acoustic correction, active filtering for type IIR and FIR loudspeakers with high-level phasing speakers.
To obtain a fully functional device:
The OpenDRC-DA8 also acts as a DAC (AKM AK4440) with its digital input SPDIF and its 8 analog RCA outputs. With its Asynchronous Sampling Rate Converter (ASRC), the digital signal is processed with a low jitter. Once configured, the configurations (4 in total) and the volume can be controlled via the rotary encoder or a remote control (not supplied), without the need for a computer.
Finally, the OpenDRC-DA8 as most MiniDSP products is intended to be an easy to use system, driven by a large community on the web working to improve and evolve the product constantly.
mini dsp DA8
Schematic diagram
TECHNICAL CHARACTERISTICS
  • Processors: Analog Devices Sharc ADSP21369
  • Processing type: 32bit floating point
  • Type of digital filter: FIR and IIR
  • Convolution engine for advanced / custom filters
  • Input: SPDIF 24bit 192khz
  • Outputs: 8x RCA Stereo with 2V Impedance 560ohm
FEATURES
  • DAC AK4440 with 8output channels
  • Front volume control
  • Remote controlled volume
  • Recall of 4 memorizable configurations
  • Active filtering 2x4 channels (8 channels)
  • Parametric Equalizer on 8 Channels
PACKAGE CONTENT
  • 1x OpenDRC-DA8
  • 1x USB Cable Type B
  • 1x Universal power supply 5VDC with UK / EU / US / AU adapters
Caution: The microphone required for digital room correction and the remote control are not supplied.
MiniDSP Processeur Audio Numérique DSP OpenDRC-DA8 Correction Acoustique
Max sampling rate192kHz
L'outil absolu.
Inconditionnel de la multi-amplification active depuis de nombreuses années, j'étais l'heureux utilisateur d'un filtre numérique avec DSP intégré depuis 4 ans. Cependant certains réglages comme l'alignement temporel des différentes voies était impossible à mener parfaitement sans corriger la phase. C'est chose possible aujourd'hui avec un appareil comme le OpenDRC-DA8 qui résout également le problème du réglage de volume en multi-voies. Un signal carré de 40 Hz reproduit par une enceinte et enregistré avec un micro placé au point d'écoute une fois les réglages terminés est dorénavant un signal carré lui aussi !
L'écoute était déjà excellente avec le filtre numérique précédent , l'amélioration n'est donc pas phénoménale, mais on a quand même l'impression de lever un léger voile sur la transcription et aussi de pouvoir pousser le volume plus loin sans effet de crispation.
Attention, l'utilisation de cet appareil requiert un apprentissage poussé de la techniques des filtres FIR et de leur conception, la maîtrise de logiciels comme Rephase (ou équivalent) et Room EQ Wizard est indispensable pour mettre correctement l'appareil en oeuvre via un ordinateur necessaire à sa programmation.
L'interface est agréable, intuitive et complète. Je suis comblé.
Deux petites critiques : La première est de ne pas savoir à quel volume se trouve réglé l'appareil. Il n'y a aucune indication d'affichée et on ne sait plus rien de lui une fois qu'il est déconnecté de l'ordinateur pour une utilisation quotidienne. Lorsqu'on pousse le volume en usage courant, rien n'indique que vous approchez le 0dB.
La deuxième concerne la puissance disponible pour utiliser les filtres FIR. L'appareil accepte jusqu'à 9600 taps en tout pour les 8 voies avec un maximum de 2048 par voie alors que pour réaliser une convolution destinée à une voie grave avec un filtrage à 96dB/octave à 100 Hz, corrigeant la phase et procédant à 4 ou 5 points d'égalisation, il faut 16000 taps. Avec 8000 taps il faut déjà faire quelques compromis avec la précision de la correction. Un ordinateur classique est capable de gérer des convolutions avec 64000 taps placés dans un lecteur logiciel comme Foobar. Il est donc dommage que miniDSP n'aie pas équipé son superbe DA8 de processeurs plus puissants.
This review has been posted for MiniDSP OpenDRC-DA8 Audio Digital Processor DSP 32bit S/PDIF RCA
