Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Lacking
The best
These are a little difficult to work with due to the hollow pins, but they are the best sound wise. Have used Viborg and others...
Astonishing- finally
I rated this cable before a few years ago when using fairly budget RCA connectors. I terminated it today with Neotech NEX GD...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 11764
    In Stock
    Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the German, French and English references enjoys a very good design quality. They are ideal for parallel RL and RLC "plug" correction in parallel circuit, instead of low quality...
    2,40 € 2,00 €Ex.
    In Stock
  • Ref : 11765
    In Stock
    2,70 € 2,25 €Ex.
    In Stock
  • Ref : 11774
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 11775
    In Stock
    18,00 € 15,00 €Ex.
    In Stock
  • Ref : 15563
    In Stock
    21,30 € 17,75 €Ex.
    In Stock
  • Ref : 11776
    In Stock
    23,20 € 19,33 €Ex.
    In Stock
  • Ref : 11766
    In Stock
    3,40 € 2,83 €Ex.
    In Stock
  • Ref : 11777
    In Stock
    25,20 € 21,00 €Ex.
    In Stock
  • Ref : 11767
    In Stock
    4,50 € 3,75 €Ex.
    In Stock
  • Ref : 11778
    29,80 € 24,83 €Ex.
    In Stock
  • Ref : 11768
    In Stock
    4,80 € 4,00 €Ex.
    In Stock
  • Ref : 11779
    In Stock
    32,20 € 26,83 €Ex.
    In Stock
  • Ref : 11769
    In Stock
    5,40 € 4,50 €Ex.
    In Stock
  • Ref : 11780
    In Stock
    37,70 € 31,42 €Ex.
    In Stock
  • Ref : 15459
    In Stock
    Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most other standard electrolytic capacitors.
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15480
    In Stock
    4,70 € 3,92 €Ex.
    In Stock
  • Ref : 15468
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15481
    In Stock
    5,40 € 4,50 €Ex.
    In Stock
  • Ref : 15469
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15482
    In Stock
    5,50 € 4,58 €Ex.
    In Stock
  • Ref : 15470
    In Stock
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15471
    In Stock
    2,10 € 1,75 €Ex.
    In Stock
  • Ref : 15458
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15460
    In Stock
    1,30 € 1,08 €Ex.
    In Stock
  • Ref : 15461
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15483
    In Stock
    6,70 € 5,58 €Ex.
    In Stock
  • Ref : 15472
    In Stock
    2,10 € 1,75 €Ex.
    In Stock
  • Ref : 15484
    In Stock
    9,40 € 7,83 €Ex.
    In Stock
  • Ref : 15473
    In Stock
    2,60 € 2,17 €Ex.
    In Stock
  • Ref : 15462
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15463
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15485
    In Stock
    10,70 € 8,92 €Ex.
    In Stock
  • Ref : 15486
    In Stock
    11,40 € 9,50 €Ex.
    In Stock
  • Ref : 15474
    In Stock
    2,80 € 2,33 €Ex.
    In Stock
  • Ref : 15475
    In Stock
    3,10 € 2,58 €Ex.
    In Stock
  • Ref : 15464
    In Stock
    1,40 € 1,17 €Ex.
    In Stock
  • Ref : 15487
    In Stock
    14,20 € 11,83 €Ex.
    In Stock
  • Ref : 15476
    In Stock
    3,30 € 2,75 €Ex.
    In Stock
  • Ref : 15465
    In Stock
    1,80 € 1,50 €Ex.
    In Stock
  • Ref : 15488
    In Stock
    16,60 € 13,83 €Ex.
    In Stock
