Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Domenico C.
Highly performing
Truly high-performance signal cables: I've tried several others over time, even more expensive ones. But these are the...
freddy w.
bluffé et dubitatif
Bj, j'ai suivi un avis au final d'un ami qui m'a assuré que j'allais tomber parterre en écoutant ce cable...
Françoise B.
Dans un système de qualité, ceux qui sont encore septique sur le traitement du signal numérique ethernet il faut essayer cet...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • 42,90 € 35,75 €Ex.
    In Stock
  • Ref : 4521
    In Stock
    The BH series combines outstanding electrical and mechanical properties that make it an excellent choice for filtering high power woofers or for any other application requiring high inductance and/or low resistance in a small volume.
    18,90 € 15,75 €Ex.
    In Stock
  • Ref : 4518
    In Stock
    15,90 € 13,25 €Ex.
    In Stock
  • Ref : 4522
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 4523
    20,90 € 17,42 €Ex.
    In Stock
  • Ref : 4525
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4519
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • 17,90 € 14,92 €Ex.
    In Stock
  • Ref : 4524
    22,90 € 19,08 €Ex.
    In Stock
  • Ref : 4515
    14,50 € 12,08 €Ex.
    In Stock
  • Ref : 4516
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 4517
    15,50 € 12,92 €Ex.
    In Stock
  • Ref : 5702
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero...
    7,60 € 6,33 €Ex.
    In Stock
  • Ref : 5703
    In Stock
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 5701
    In Stock
    7,30 € 6,08 €Ex.
    In Stock
  • Ref : 5706
    In Stock
    9,10 € 7,58 €Ex.
    In Stock
  • Ref : 5708
    In Stock
    9,90 € 8,25 €Ex.
    In Stock
  • Ref : 5710
    In Stock
    11,90 € 9,92 €Ex.
    In Stock
  • Ref : 5712
    In Stock
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 5724
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 5725
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 5726
    In Stock
    42,90 € 35,75 €Ex.
    In Stock
  • Ref : 5704
    In Stock
    8,30 € 6,92 €Ex.
    In Stock
  • Ref : 5705
    In Stock
    8,70 € 7,25 €Ex.
    In Stock
  • Ref : 5707
    In Stock
    9,50 € 7,92 €Ex.
    In Stock
  • Ref : 5709
    In Stock
    10,90 € 9,08 €Ex.
    In Stock
  • Ref : 5711
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 5714
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 5715
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 5716
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 5727
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 5713
    In Stock
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 5718
    In Stock
    23,90 € 19,92 €Ex.
    In Stock
  • Ref : 5719
    25,90 € 21,58 €Ex.
    In Stock
  • Ref : 5717
    In Stock
    21,90 € 18,25 €Ex.
    In Stock
  • Ref : 5721
    In Stock
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 5722
    In Stock
    31,90 € 26,58 €Ex.
    In Stock
  • Ref : 5720
    In Stock
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 5723
    In Stock
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 4196
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion. For this reason, Mundorf produces coils with a large wire diameter for purists. It is therefore possible to achieve better inductances while maintaining low internal impedance and zero distortion.
    11,90 € 9,92 €Ex.
    In Stock
