Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Pierre X.
DAC conforme à mes attentes
Je n'ai pas un système incroyable (ampli Scott 330RL + enceintes Merxcuriale ) mais en remplaçant une carte son bas de...
Pierre X.
câble de bonne qualité
bon rapport qualité / prix
Guy C.
Selecteur de sources
possesseur du HPA-S500ET avec purifi 1ET7040SA qui apparemment n est plus au catalogue, je peux affirmer que le produit est...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 1670
    In Stock
    Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this reason, Mundorf produces coils with a large wire diameter for purists. This makes it possible to achieve better inductances while maintaining low internal impedance and zero...
    65,50 € 54,58 €Ex.
    In Stock
  • Ref : 1657
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 1661
    41,90 € 34,92 €Ex.
    In Stock
  • Ref : 1662
    In Stock
    45,90 € 38,25 €Ex.
    In Stock
  • Ref : 4574
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 1663
    In Stock
    51,90 € 43,25 €Ex.
    In Stock
  • Ref : 1664
    In Stock
    58,90 € 49,08 €Ex.
    In Stock
  • Ref : 4575
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 1665
    In Stock
    66,90 € 55,75 €Ex.
    In Stock
  • Ref : 1666
    74,90 € 62,42 €Ex.
    In Stock
  • Ref : 1667
    82,90 € 69,08 €Ex.
    In Stock
  • Ref : 1668
    In Stock
    91,90 € 76,58 €Ex.
    In Stock
  • Ref : 3356
    In Stock
    12,90 € 10,75 €Ex.
    In Stock
  • Ref : 3357
    In Stock
    14,70 € 12,25 €Ex.
    In Stock
  • Ref : 3354
    In Stock
    11,00 € 9,17 €Ex.
    In Stock
  • Ref : 3358
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 3359
    In Stock
    18,50 € 15,42 €Ex.
    In Stock
  • 61,90 € 51,58 €Ex.
    In Stock
  • 69,90 € 58,25 €Ex.
    In Stock
  • Ref : 3371
    In Stock
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 3372
    In Stock
    115,00 € 95,83 €Ex.
    In Stock
  • Ref : 3374
    In Stock
    175,00 € 145,83 €Ex.
    In Stock
  • Ref : 3375
    In Stock
    125,00 € 104,17 €Ex.
    In Stock
  • Ref : 3377
    In Stock
    169,00 € 140,83 €Ex.
    In Stock
  • Ref : 3378
    In Stock
    97,50 € 81,25 €Ex.
    In Stock
  • Ref : 2391
    In Stock
    30,90 € 25,75 €Ex.
    In Stock
  • Ref : 2390
    In Stock
    28,90 € 24,08 €Ex.
    In Stock
  • Ref : 2392
    In Stock
    46,90 € 39,08 €Ex.
    In Stock
  • Ref : 2394
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 2396
    In Stock
    38,90 € 32,42 €Ex.
    In Stock
  • Ref : 2397
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 2402
    In Stock
    94,90 € 79,08 €Ex.
    In Stock
  • Ref : 2413
    In Stock
    167,30 € 139,42 €Ex.
    In Stock
  • Ref : 2409
    In Stock
    183,90 € 153,25 €Ex.
    In Stock
  • Ref : 5096
    In Stock
    42,90 € 35,75 €Ex.
    In Stock
  • Ref : 5094
    In Stock
    55,90 € 46,58 €Ex.
    In Stock
  • Ref : 5098
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 5099
    In Stock
    71,90 € 59,92 €Ex.
    In Stock
  • Ref : 5102
    In Stock
    84,90 € 70,75 €Ex.
    In Stock
  • Ref : 5103
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
