Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Pierre X.
DAC conforme à mes attentes
Je n'ai pas un système incroyable (ampli Scott 330RL + enceintes Merxcuriale ) mais en remplaçant une carte son bas de...
Pierre X.
câble de bonne qualité
bon rapport qualité / prix
Guy C.
Selecteur de sources
possesseur du HPA-S500ET avec purifi 1ET7040SA qui apparemment n est plus au catalogue, je peux affirmer que le produit est...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 10787
    In Stock
    Since 2015, the MCap Supreme EVO SilverGold capacitors have been the undisputed top-of-the-line product from Mundorf. It combines all of the brand's technical strengths, such as SilverGold metallization, SUPREME and EVOLUTION winding technology and more than 30 years of experience in the manufacture of capacitors for incredible musicality.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 10789
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 10790
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 10791
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 10792
    In Stock
    79,90 € 66,58 €Ex.
    In Stock
  • Ref : 10785
    In Stock
    35,90 € 29,92 €Ex.
    In Stock
  • Ref : 10794
    In Stock
    Since 2015, the MCap Supreme EVO SilverGold and MCap Supreme EVO SilverGold OIL capacitors have been the undisputed top-of-the-line products from Mundorf. It combines all of the brand's technical strengths, such as SilverGold metallization, SUPREME and EVOLUTION winding technology, and more than 30 years of experience in manufacturing capacitors that...
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 10793
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 10811
    599,90 € 499,92 €Ex.
    In Stock
  • Ref : 10812
    Reduced price!
    In Stock
    655,90 € 546,58 €Ex.
    699,90 € In Stock
  • Ref : 10810
    In Stock
    499,90 € 416,58 €Ex.
    In Stock
  • Ref : 10808
    In Stock
    299,90 € 249,92 €Ex.
    In Stock
  • Ref : 10795
    In Stock
    109,90 € 91,58 €Ex.
    In Stock
  • Ref : 10797
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 10798
    129,90 € 108,25 €Ex.
    In Stock
  • Ref : 10799
    139,90 € 116,58 €Ex.
    In Stock
  • Ref : 10800
    In Stock
    125,90 € 104,92 €Ex.
    In Stock
  • Ref : 10801
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 10803
    In Stock
    179,90 € 149,92 €Ex.
    In Stock
  • Ref : 10804
    134,90 € 112,42 €Ex.
    In Stock
  • Ref : 10805
    In Stock
    199,90 € 166,58 €Ex.
    In Stock
  • Ref : 10806
    152,90 € 127,42 €Ex.
    In Stock
  • Ref : 10807
    In Stock
    249,90 € 208,25 €Ex.
    In Stock
  • Ref : 1770
    In Stock
    Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor coating and the winding is impregnated with a special oil.
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 1776
    Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor coating and the winding is impregnated with a special oil that has been developed through extensive testing and listening.
    41,90 € 34,92 €Ex.
    In Stock
  • 51,90 € 43,25 €Ex.
    In Stock
  • Ref : 1779
    In Stock
    61,90 € 51,58 €Ex.
    In Stock
  • Ref : 1780
    In Stock
    71,90 € 59,92 €Ex.
    In Stock
  • Ref : 1782
    In Stock
    82,90 € 69,08 €Ex.
    In Stock
  • Ref : 1785
    In Stock
    104,90 € 87,42 €Ex.
    In Stock
  • Ref : 1784
    In Stock
    93,90 € 78,25 €Ex.
    In Stock
  • Ref : 1787
    In Stock
    124,90 € 104,08 €Ex.
    In Stock
  • Ref : 1789
    In Stock
    144,90 € 120,75 €Ex.
    In Stock
  • Ref : 1790
    In Stock
    194,90 € 162,42 €Ex.
    In Stock
  • Ref : 1791
    In Stock
    229,90 € 191,58 €Ex.
    In Stock
  • Ref : 1792
    Reduced price!
    In Stock
    279,90 € In Stock
  • Ref : 1793
    In Stock
    In Stock
  • Ref : 2181
    In Stock
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 2174
    In Stock
    33,90 € 28,25 €Ex.
    In Stock
  • Ref : 2182
    30,90 € 25,75 €Ex.
    In Stock
