Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Bruno R.
Étonnant
Sur un conseil d'expert je l' ai ajouté en parallèle sur deux condos Evo oil 30μf , eux même en parallèle, sur voix...
eric m.
5AR4 TS
Merci à toute l'équipe pour l'efficacité du traitement de ma commande.
Tube Tungsol 5AR4 de bonnes factures.
En...
WOONG KYU J.
OPA1612 GOOD !!!
Replacing the LME49720 with the OPA1612...
From fast transitions and crispness to solid bass...
It is a truly excellent...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 4064
    In Stock
    The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4065
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4066
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4075
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4076
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4077
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4078
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4067
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4068
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4079
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 6436
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4069
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4070
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4080
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 15336
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4071
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 16061
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4072
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4073
    In Stock
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 4074
    24,90 € 20,75 €Ex.
    In Stock
  • Ref : 16109
    The development of Mundorf MResist Ultra resistors is based on the excellent tonal properties of the copper-manganese foil. Compared to all wirewound resistors, this film offers lower inductance. The copper is significantly softer than the metal oxide used in MOX resistors.
    16,10 € 13,42 €Ex.
    In Stock
  • Ref : 16113
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16114
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16115
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16116
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16118
    Out of stock
    26,90 € 22,42 €Ex.
    Out of stock
  • Ref : 16122
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16123
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16124
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16125
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16134
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16136
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16137
    In Stock
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16126
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16127
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16138
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16143
    In Stock
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 16128
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16129
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
  • Ref : 16140
    In Stock
    37,90 € 31,58 €Ex.
    In Stock
