SHANLING SM1.3R Streamer DAC Headphone Amplifier Black
-22%
With the SM1.3R, Shanling presents a network player and DAC designed to serve as the heart of any hi-fi system. Thanks to the brand’s in-house developed R2R DAC, it supports digital signals up to 32-bit 768kHz PCM and DSD512. Compatible with numerous streaming services and network protocols, such as DLNA, AirPlay 2, Samba, Roon Ready, Tidal Connect and Qobuz Connect, it integrates easily into any audio setup.
Reduced price!
Reference : 21781
1 799,00 €tax incl.
-22%
1 399,00 €tax incl.
1 165,83 € tax excl.
Shipping date: 01-12-2026.
Shanling SM1.3R Streamer R2R DAC Headphone Amplifier WiFi LAN Bluetooth 32bit 768kHz DSD512 Black
Shanling SM1.3R : Front view
Shanling SM1.3R: A powerful device
The SM1.3R has been developed using the 64-bit ARM Cortex-A55 processor and is intended to set the new benchmark for the next generation of Shanling network players. It runs on a heavily modified version of Android 12, optimised for Hi-Fi use. It also features 4GB of RAM, 64GB of storage and an M.2 SSD slot (SSD not included).
Shanling SM1.3R : CPU
Shanling SM1.3R : Silver and black version
Shanling SM1.3R: A refined aesthetic
The SM1.3R’s design follows the standard set by their MCD1.3 CD player and features the same minimalist aesthetic, allowing it to blend seamlessly into any interior. The aluminium body with rounded corners, the glass top panel, and the inclusion of a 5.8-inch 1080p touchscreen combine to create a device that is both elegant and robust.
Shanling SM1.3R: New user interface
As the SM1.3R is intended to be Shanling’s new benchmark, the brand has taken the opportunity to completely redesign its user interface. This new interface focuses on simpler and faster access to all levels of the system, with an optimised main menu, settings and playback controls. The reduced number of elements and the clarity of the icons result in a cleaner look for the system and faster navigation.
Shanling SM1.3R : UI
Shanling SM1.3R: Extended compatibility
Designed to be both comprehensive and user-friendly, the SM1.3R comes with a range of built-in streaming apps, including Spotify, Tidal, Qobuz, Apple Music, Apple Classical, Presto Music and KKBox. It is also compatible with DLNA, AirPlay 2, Roon Ready, Tidal Connect and Qobuz Connect, ensuring easy access to your music. Finally, you can also connect the SM1.3 to your NAS thanks to Samba support.
Shanling SM1.3R: Silent power supply
The SM1.3R’s power supply has been designed to minimise interference. Two 31W toroidal transformers independently power the mains and audio sections, providing a stable, low-noise linear power supply for optimal audio performance.
Shanling SM1.3R : Power supply
Shanling SM1.3R : OPA
Shanling SM1.3R: Cutting-edge audio signal processing
The SM1.3R features the second generation of Shanling’s in-house developed 2R2 DAC, based on a fully discrete topology. The circuit comprises a total of 212 resistors matched to 0.01%, distributed across four channels to achieve 24-bit conversion.
In this architecture, 19 bits are dedicated to the actual conversion, whilst 4 bits are used to compensate for residual errors and 1 bit drives a push-pull differential circuit, which balances the positive and negative half-cycles of the signal. This hierarchical allocation optimises low-level accuracy whilst stabilising the dynamic behaviour.
The line output, featuring a MUSES8920 operational amplifier, can also be used as a preamplifier, whilst a 6.35 mm headphone output with a dedicated TPA6120 operational amplifier provides high-quality headphone amplification.
Shanling SM1.3R: Extensive connectivity
The SM1.3R ensures a fast and stable connection thanks to its Ethernet port and Wi-Fi 6 compatibility. It also supports Bluetooth 5.2 with high-resolution codecs such as LDAC, aptX, aptX HD, aptX Adaptive and aptX Low Latency, guaranteeing optimal audio quality.
Shanling SM1.3R : WiFi 6
Shanling SM1.3R : Clock
Shanling SM1.3R: ACCUSILICON internal clocks
For maximum precision, the SM1.3R features ACCUSILICON clocks (45.1584 MHz and 49.152 MHz), which are essential for high-resolution audio decoding. Combined with Shanling’s AGLO (Android Global Lossless Output) system, they ensure bit-perfect sound reproduction, even on an Android platform.
Shanling SM1.3R: XMOS XU316
The SM1.3R features a USB interface based on the XMOS XU316 microcontroller, capable of handling PCM signals up to 32-bit/768kHz and DSD512. This component ensures fast and accurate transmission of audio streams via USB.
Shanling SM1.3R : XMOS chip
Shanling SM1.3R : Shanling app
Shanling SM1.3R: Eddict Player app
The Eddict Player app, available on Android and iOS, has been redesigned to offer an experience similar to that of the SM1.3R interface. It allows you to control the device remotely as if you were interacting with it directly, making it even more intuitive to use.
Shanling SM1.3R : Pinout I2S
Shanling SM1.3R: Remote control
Shanling SM1.3R : Remote control
Product typeStreamer
DAC
Headphone amplifier
Inputs1x Ethernet RJ45
1x Coaxial
1x Optical Toslink
1x USB-C
2x USB-A
1x Balanced stereo XLR
1x HDMI I2S
1x Coaxial
1x Optical Toslink
1x 6.35mm jack headphone output
Wireless connectivityWiFi 6 Dual-band 2.4G/5G
Bluetooth 5.2
DACR2R
Touch screen5.8" 1080p
OSCustom Android 12
Supported Bluetooth codecsLDAC / aptX HD / aptX Adaptative / aptX Low-Latency / aptX / AAC / SBC
Supported sampling ratesPCM 32bit 768kHz
DSD512
MQA
Supported audio formatsDSD, DXD, APE, FLAC, WAV, AIFF/AIF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, OPUS, TAK, CUE
Compatible streaming servicesAirPlay
Amazon Music
DLNA
Qobuz
Qobuz Connect
Spotify
Tidal
Tidal Connect
Roon Ready
Headphone output powerLow gain : 17mW @ 32Ω
Medium gain : 159mW @ 32Ω
High gain : 900mW @ 32Ω
High gain : 130mW @ 300Ω
Output levelRCA : 2.2V
XLR : 4.4V
Frequency response20Hz - 40kHz (-0.5dB)
Total harmonic distortion more noise (THD+N)RCA : 0.003%
XLR : 0.003%
Jack 6.35mm : 0.003% @ 32Ω
Dynamic range (DNR)RCA : 118dB
XLR : 120dB
Jack 6.35mm : 116dB @ 32Ω
Signal-to-noise ratio (SNR)RCA : 118dB
XLR : 120dB
Channel separationRCA : 116dB
XLR : 117dB
Jack 6.35mm : 70dB @ 32Ω
Storage capacity64GB + Slot SSD M.2
Output impedanceJack 6.35mm : 4.7Ω
Power supply voltage220V AC
Dimensions280 x 280 x 110mm
Weight6.4kg
Package1x Shanling SM1.3R
1x Remote control
1x USB-A to USB-C cable
1x Power cable
3x WiFi/Bluetooth antennas
InputRJ45
OutputOptical Toslink
OutputJack 6.35mm
OutputCoaxial SPDIF
DAC / ADC ChipR2R LADDER DAC
Max sampling rate768kHz
Max sampling rateDSD512
ClassN/A
NetworkingYes
Remote ControlYes
Streaming services & Network protocolsDLNA
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsApple Music
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsQobuz Connect
SHANLING SM1.3R Streamer R2R DAC Headphone Amplifier WiFi LAN Bluetooth 32bit 768kHz DSD512 Black
With the SM1.3R, Shanling presents a network player and DAC designed to serve as the heart of any hi-fi system. Thanks to the brand’s...
