Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
4 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Adam K.
Holo Cyan 2 - wysyłka do Polski
Na początku kilka słów o samym zakupie. DAC został bardzo szybko wysłany, był dobrze zabezpieczony i dotarł bez żadnych...
Francois P.
J'ai associé ce préampli avec l'ampli de puissance AUDIOPHONICS LPA-S450ET et j'avoue que je suis séduit par le...
dominique w.
Qualité apparente des connecteurs. Câble trés souple. Permet avant tout de profiter des bénéfices d'une liaison symétrique...
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 1702
    The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
    209,90 € 174,92 €Ex.
    In Stock
  • Ref : 1700
    145,90 € 121,58 €Ex.
    In Stock
  • Ref : 1703
    219,90 € 183,25 €Ex.
    In Stock
  • Ref : 1704
    279,90 € 233,25 €Ex.
    In Stock
  • Ref : 1705
    299,90 € 249,92 €Ex.
    In Stock
  • Ref : 1706
    319,90 € 266,58 €Ex.
    In Stock
  • Ref : 6078
    Metal foil coils are physically the best designed. The output quality is consistent up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    679,90 € 566,58 €Ex.
    In Stock
  • Ref : 6079
    759,90 € 633,25 €Ex.
    In Stock
  • Ref : 6080
    Metal foil coils are physically the best designed. Output quality is constant up to 100kHz, and unwanted capacitive loads are very low. Coil stability is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    849,90 € 708,25 €Ex.
    In Stock
  • Ref : 6077
    629,90 € 524,92 €Ex.
    In Stock
  • 949,90 € 791,58 €Ex.
    In Stock
  • Ref : 6082
    1 059,90 € 883,25 €Ex.
    In Stock
  • Ref : 6083
    1 199,90 € 999,92 €Ex.
    In Stock
  • Ref : 6084
    1 295,90 € 1 079,92 €Ex.
    In Stock
  • 1 441,90 € 1 201,58 €Ex.
    In Stock
  • Ref : 6087
    1 789,90 € 1 491,58 €Ex.
    In Stock
  • Ref : 6088
    1 989,90 € 1 658,25 €Ex.
    In Stock
  • Ref : 6089
    2 229,90 € 1 858,25 €Ex.
    In Stock
  • Ref : 4419
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    104,90 € 87,42 €Ex.
    In Stock
  • Ref : 2199
    175,90 € 146,58 €Ex.
    In Stock
  • Ref : 3654
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 20407
    The metallization of the Mundorf MCap Supreme SilverGold capacitor foil is composed of pure silver mixed with 1% very pure gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity. The outstanding characteristics of the MCap Supreme - richness of detail and spatial quality of the music reproduced - are once...
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 3655
    In Stock
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 3656
    In Stock
    49,90 € 41,58 €Ex.
    In Stock
  • Ref : 3657
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 3658
    In Stock
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 3659
    In Stock
    77,50 € 64,58 €Ex.
    In Stock
  • Ref : 3661
    In Stock
    99,90 € 83,25 €Ex.
    In Stock
  • Ref : 3670
    In Stock
    329,90 € 274,92 €Ex.
    In Stock
  • Ref : 3660
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 3662
    119,90 € 99,92 €Ex.
    In Stock
  • Ref : 3664
    In Stock
    139,90 € 116,58 €Ex.
    In Stock
  • Ref : 3665
    In Stock
    159,90 € 133,25 €Ex.
    In Stock
  • Ref : 3666
    In Stock
    189,90 € 158,25 €Ex.
    In Stock
  • Ref : 3668
    In Stock
    269,90 € 224,92 €Ex.
    In Stock
  • Ref : 3669
    In Stock
    239,00 € 199,17 €Ex.
    In Stock
  • Ref : 3667
    In Stock
  • Ref : 2035
    These capacitors combine high dielectric strength with low residual inductance. They have been developed to offer a high quality alternative to high voltage electrochemical capacitors and are therefore ideal for use in tube amplifiers.
    26,90 € 22,42 €Ex.
    In Stock
  • Ref : 2031
    In Stock
    129,90 € 108,25 €Ex.
    In Stock
  • Ref : 2030
    In Stock
    In Stock
