Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
Pascal H.
Marc C.
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 1709
    In Stock
    The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
    399,00 € 332,50 €Ex.
    In Stock
  • Ref : 1710
    In Stock
    In Stock
  • Ref : 1694
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 1698
    139,00 € 115,83 €Ex.
    In Stock
  • Ref : 1699
    145,00 € 120,83 €Ex.
    In Stock
  • Ref : 1701
    In Stock
  • Ref : 1702
    In Stock
    185,00 € 154,17 €Ex.
    In Stock
  • Ref : 1700
    In Stock
  • Ref : 1703
    In Stock
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 1704
    209,00 € 174,17 €Ex.
    In Stock
  • Ref : 1705
    215,00 € 179,17 €Ex.
    In Stock
  • Ref : 1706
    219,00 € 182,50 €Ex.
    In Stock
  • Ref : 6078
    Metal foil coils are physically the best designed. The output quality is consistent up to 100kHz and unwanted capacitive loads are very low. The stability of the coil is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    717,30 € 597,75 €Ex.
    In Stock
  • Ref : 6079
    800,70 € 667,25 €Ex.
    In Stock
  • Ref : 6080
    Metal foil coils are physically the best designed. Output quality is constant up to 100kHz, and unwanted capacitive loads are very low. Coil stability is also remarkable: thanks to the large contact area between the winding and the polypropylene insulator, vibrations are eliminated.
    895,20 € 746,00 €Ex.
    In Stock
  • Ref : 6077
    666,10 € 555,08 €Ex.
    In Stock
  • 1 000,80 € 834,00 €Ex.
    In Stock
  • Ref : 6082
    1 117,60 € 931,33 €Ex.
    In Stock
  • Ref : 6083
    1 266,60 € 1 055,50 €Ex.
    In Stock
  • Ref : 6084
    1 367,80 € 1 139,83 €Ex.
    In Stock
  • 1 522,40 € 1 268,67 €Ex.
    In Stock
  • Ref : 6087
    1 889,40 € 1 574,50 €Ex.
    In Stock
  • Ref : 6088
    2 100,60 € 1 750,50 €Ex.
    In Stock
  • Ref : 6089
    2 356,40 € 1 963,67 €Ex.
    In Stock
  • Ref : 4419
    The metallization of the MCap Supreme SilverGold capacitor foil is composed of pure Silver mixed with 1% very pure Gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity.
    60,30 € 50,25 €Ex.
    In Stock
  • Ref : 2199
    181,20 € 151,00 €Ex.
    In Stock
  • Ref : 3654
    In Stock
    35,20 € 29,33 €Ex.
    In Stock
  • Ref : 20407
    The metallization of the Mundorf MCap Supreme SilverGold capacitor foil is composed of pure silver mixed with 1% very pure gold. Gold modifies the crystal structure of silver and maximizes its excellent electrical conductivity. The outstanding characteristics of the MCap Supreme - richness of detail and spatial quality of the music reproduced - are once...
    47,90 € 39,92 €Ex.
    In Stock
  • Ref : 3655
    In Stock
    34,90 € 29,08 €Ex.
    In Stock
  • Ref : 3656
    In Stock
    43,90 € 36,58 €Ex.
    In Stock
  • Ref : 3657
    In Stock
    55,90 € 46,58 €Ex.
    In Stock
  • Ref : 3658
    60,00 € 50,00 €Ex.
    In Stock
  • Ref : 3659
    In Stock
    75,90 € 63,25 €Ex.
    In Stock
  • Ref : 3661
    In Stock
    92,00 € 76,67 €Ex.
    In Stock
  • Ref : 3670
    In Stock
    259,00 € 215,83 €Ex.
    In Stock
  • Ref : 3660
    In Stock
    89,90 € 74,92 €Ex.
    In Stock
  • Ref : 3662
    In Stock
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 3664
    In Stock
    In Stock
  • Ref : 3665
    In Stock
    In Stock
  • Ref : 3666
    In Stock
    155,00 € 129,17 €Ex.
    In Stock
