Tolerance (%)
0 % - 20 %
Capacitor capacitance (µF)
Capacitor format
Capacitor type
Inductance (mh)
Power (W)
0 - 250
Rated voltage (V)
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 5 A
Rated current (A)
Resistance (Ohm)
Section (mm²)
0 mm - 1 mm
Contacts number
7 - 9
Channel
Max panel thickness
mm
mm
Color
Electronic components
patrice f.
Soundcare standard
Dimitrios K.
Neotech usb cable
Pierre H.
Condo Mundorf 22000µF/63V
  • Capacitors
    Capacitors
  • Selfs & Coils
    Selfs & Coils
  • Resistors
    Resistors
  • Potentiometers
    Potentiometers
  • Selectors
    Selectors
  • OPA Adapters
    OPA Adapters
  • Universal circuit boards
  • Relays
    Relays
  • Fuse and Circuit breaker
  • OPA
    OPA
  • Transistors
    Transistors
  • Speaker L-control
    Speaker L-control
  • Voltage Regulator
    Voltage Regulator
  • Clocks
    Clocks
  • Light Bulbs and LED
    Light Bulbs and LED
  • Tubes and lamps
    Tubes and lamps
  • Audio Transformer
    Audio Transformer
  • Ref : 16032
    In Stock
    The 6L6WXT+ power tube is based on the vintage RCA 6L6GC design. However, it features larger plate dimensions and an improved grille structure for better power handling. It also features mica spacers with metal springs to eliminate noise and microphony.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 6429
    In Stock
    17,90 € 14,92 €Ex.
    In Stock
  • Ref : 16031
    In Stock
    The Sovtek EL84SOV/6BQ5 is a pentode tube with equipotential cathode, designed to amplify low frequency power in the output stages of HiFi audio devices. It offers a soft, warm and round sound reproduction.
    36,90 € 30,75 €Ex.
    In Stock
  • Ref : 16030
    In Stock
    16,90 € 14,08 €Ex.
    In Stock
  • Ref : 13906
    In Stock
    Some discrete OPA use a different pinout from the DIP8 standard, such as the SS2590 from Sparkos Labs. This API to DIP8 adapter will therefore allow you to use such a OPA on DIP8 support. Mounting is simple since it is enough to place your OPA on the adapter and make a few solderings and then cut the legs that protrude under the PCB.
    13,90 € 11,58 €Ex.
    In Stock
  • Ref : 15071
    In Stock
    This adapter allows you to simultaneously install two Sparkos discrete AOPs (tyoe SS2590) on a stereo connector on DIP8. It thus allows a pair of sparkos discrete mono AOPs to be used on a stereo AOP slot.
    14,90 € 12,42 €Ex.
    In Stock
  • Ref : 13969
    In Stock
    The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of discrete regulators designed to replace adjustable monolithic regulators. They are in the standard format TO-220 with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14484
    44,94 € 37,45 €Ex.
    In Stock
  • Ref : 14518
    The Sparkos Labs brand, which specializes in the design of high quality discrete electronic components, has created a range of discrete controllers to advantageously replace adjustable monolithic controllers. They are in the standard TO-220 format with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18351
    In Stock
    The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of ré discrete regulators designed to replace adjustable monolithic regulators. They are in the standard format TO-220 with 3 pins and have a fixed voltage with more than 1A available at the output.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 13304
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18352
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18353
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18979
    In Stock
    After the undeniable success of the SS3601 and SS3602 discrete OPA, SparkoS Labs focused on discrete OPA that can be found in studio equipment or recording devices, such as the API2520 operational amplifier or the Jensen 990. After numerous tests and measurements, SparkoS Labs decided to offer a much more efficient OPA. Here, two SS2590 AOPs have...
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 13897
    In Stock
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 13168
    In Stock
    SparkoS Labs has created a range of discrete DIP8-mounted PDOs optimized to deliver excellent audio performance. They will allow you to replace less powerful AOP or quite simply to obtain a different sound.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 13169
    In Stock
    85,00 € 70,83 €Ex.
    In Stock
  • Ref : 14810
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18874
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 13968
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14497
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 16070
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 17391
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14036
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14856
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 18875
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14280
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14485
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 16071
    In Stock
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 17392
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 14561
    In Stock
    This ST LM317T 3-terminal voltage regulator in TO-220 package has an input voltage range of -0.3V to 40VDC for an output voltage range of 1.2V to 37VDC and an output current of 1.5A.
    1,00 € 0,83 €Ex.
    In Stock
  • Ref : 18949
    In Stock
    Staccato's open-loop OSH-DHA OPA is there to magnify the sound of high-end DACs and preamplifiers. The use of J-FET, in both input and output stage, in combination with high bias current, had result in low open loop distortion with dominating of 2nd harmonic.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 18951
    In Stock
    Staccato's open-loop OSH-DHB AOP is there to magnify the sound of high-end DACs and preamplifiers. The use of J-FET, in both input and output stage, in combination with high bias current, had result in low Open loop distortion with dominating of 2. harmonic. The source follower at the output using an active current source which allow higher output current...
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 18963
    In Stock
    Staccato's open-loop OSH-DV OPA is there to magnify the sound of high-end DACs and preamplifiers. The use of J-FET, in both input and output stage, in combination with high bias current, had result in low Open loop distortion with dominating of 2. harmonic. The source follower at the output using an active current source which allow higher output current...
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 18964
    In Stock
    Staccato's open-loop OSH-S OPA is there to magnify the sound of high-end DACs and preamplifiers. The use of J-FET, in both input and output stage, in combination with high bias current, had result in low Open loop distortion with dominating of 2. harmonic. The source follower at the output using an active current source which allow higher output current...
    49,90 € 41,58 €Ex.
    In Stock
  • 39,90 € 33,25 €Ex.
    In Stock
  • 46,90 € 39,08 €Ex.
    In Stock
  • Ref : 12710
    In Stock
    Stepped attenuators have the advantage over conventional potentiometers that they do not generate distortion and therefore offer a less degraded and cleaner sound.
    46,90 € 39,08 €Ex.
    In Stock
  • 3,20 € 2,67 €Ex.
    In Stock
