JANTZEN AUDIO AMBER Z-CAP C&B 001-7306 Pure Copper Foil Capacitor Axial 630V 0.1µF
Jantzen Audio's Amber Z-Cap C&B capacitors are premium audiophile pure copper foil capacitors specifically developed for coupling and bypass applications.
Reference : 22174
22,50 €tax incl.
18,75 € tax excl.
Shipping date: 17-11-2026.
Jantzen Amber Z-Cap C&B 001-7306 Pure Copper Foil Capacitor Axial 630V 0.1µF
Jantzen Audio Amber Z-Cap
Jantzen Audio's Amber Z-Cap C&B capacitors are premium audiophile pure copper foil capacitors specifically developed for coupling and bypass applications. With a 630VDC voltage rating, they are ideally suited for tube amplifiers and are also an excellent choice for high-end solid-state amplifiers requiring premium coupling capacitors. Their pure copper foil construction combined with a polypropylene film dielectric ensures exceptional transparency, ultra-low distortion, and minimal losses, preserving the full integrity and musicality of the audio signal.
Key features:
  • Premium audiophile capacitor specifically designed for Coupling & Bypass applications.
  • High-purity pure copper foil construction for excellent conductivity.
  • Polypropylene film dielectric with extremely low dielectric absorption.
  • 630VDC voltage rating, ideal for tube amplifier applications.
  • Extremely low ESR, ESL, and parasitic inductance.
  • Non-inductive metal-sprayed zinc end connections.
  • 99.99% tinned OFC copper leads.
  • Anodized aluminum housing for excellent mechanical protection.
  • Natural, transparent sound reproduction with exceptionally low distortion.
  • Recommended for coupling capacitor applications in high-end amplifiers and as a bypass capacitor in audiophile designs.
Capacitor typeNon-polarized pure copper film capacitor
DielectricPolypropylene film
FormatAxial
Rated voltage630VDC
350VAC
Capacitance0.1µF
Capacitance tolerance+/-5%
Dissipation factorExtremely low
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thickness5µm
ESRExtremely low
Self inductance0nH
Insulation resistance> 100 000 MOhm @ 20°C
Temperature range-55°C / +85°C
Metal layer thickness0.3µm
Conductivity of the metal layer1.2Ω/cm²
DimensionsØ24 x 32mm
ColorBrown
Tolerance (%)5
Capacitor capacitance (µF)0.1
Rated voltage (V)350.0
Rated voltage (V)630.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Ils ont magnifié mon préampli
En remplacement de condensateurs wima Mkp à deux emplacements sur le trajet du signal de mon préampli Cay HH-1. Bas medium charnel sur les voix, les instruments, transparence et amélioration de la profondeur de scène, on y gagne bien sûr sur tous les registres. N'hésitez pas à passer directement à ce haut de gamme directement
This review has been posted for JANTZEN AUDIO AMBER Z-CAP C&B 001-7306 Pure Copper Foil Capacitor Axial 630V 0.1µF
Jantzen Audio's Amber Z-Cap C&B capacitors are premium audiophile pure copper foil capacitors specifically developed for coupling and...
