RAMM AUDIO SCHUKO-01RC Schuko Connector
The SCHUKO-01RC from Ramm Audio is a Schuko connector with a high-quality black nylon and polycarbonate body. Aesthetic and sturdy, this chassis is ideal for integrating sophisticated, high-end cables. Its proportions make it the perfect choice for cables and conductors with a large diameter.
Reference : 20872
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 16-12-2025.
Ramm Audio SCHUKO-01RC Schuko Connector E/F Type 16A Gold-plated Copper Ø17mm
Ramm Audio SCHUKO-01RC : Front view
This connector accepts cables with a diameter of up to Ø17mm. Thanks to a rubber cable clamp, your thick cables will be held securely in place. The pure copper contacts are cryogenically treated and plated with 3µ thick 24k gold for maximum conductivity and increased resistance to oxidation and corrosion.
Finally, it should also be noted that the internal connection terminals are equipped with large fixing screws and a particularly large contact surface. This means that no soldering is required to integrate your cable, and large-diameter conductors are held firmly in place.
Product typeMale Schuko connector
Mounting typeTo screw
Max cable diameterØ17mm
Max conductors section5.26mm² (10 AWG)
Contacts treatmentCryogenic
Contacts platingGold 24k 3µ
Conductive materialPure cooper
Current / Voltage16A / 250V
Dimensions39.5 x 92.6mm
Weight82g
PackageSold by unit
Max cable diameter (mm)17.0
ConnecticMale
ConnectorSchuko
Rated current (A)16.0
RAMM AUDIO SCHUKO-01RC Schuko Connector E/F Type 16A Gold-plated Copper Ø17mm
The SCHUKO-01RC from Ramm Audio is a Schuko connector with a high-quality black nylon and polycarbonate body. Aesthetic and sturdy, this chassis is...
