VIBORG VE512G Schuko Type E/F Power Connector Silver / Gold Plated Pure Copper Ø20mm
This Viborg VE512G Schuko power connector is of exceptional design quality, using only the highest quality materials to ensure the best possible signal transmission. The contacts are made of pure copper with OFC copper, silver and gold plating for optimal electrical conductivity.
Reference : 17502
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 10-06-2026.
Viborg VE512G
This Schuko Viborg VE512G mains connector benefits from exceptional design quality, using only high quality materials to promote the best possible signal transmission. There are thus pure copper contacts with OFC copper, silver and gold plating, ensuring optimal electrical conductivity. The body is made of a sturdy aluminum alloy and Bayer-2805 plastic. The assembly of the cable is done simply, the conductors being fixed using a system to screw. The VE512G accepts cables with a maximum diameter of 20mm and conductors with a diameter of up to 4.5mm.
Product typePower connector
ConnectorMale Schuko
Contacts materialPure copper
Contacts plating1. OFC Copper
2. Silver
3. Gold 24K
Body materialAluminum alloy
Bayer-2805 plastic
Max cable diameterØ20mm
Max conductors diameterØ4.5mm
Voltage/Current250V AC 16A
Total dimensions98.6 x 40mm
ColorSilver and transparent
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorSchuko
Rated current (A)16.0
2 reviews
Bravo Viborg
Connecteur de conception exceptionnelle, traitement des contacts cuivre OFC, argent et or super bien realisés .Corps en alliage d'aluminium isolé interieurement , montage facile .
Rapport qualité rendu musicale extraordinaire.
Que demander de plus à ce prix c'est imbattable !!!
This review has been posted for VIBORG VE512G Schuko Type E/F Power Connector Silver / Gold Plated Pure Copper Ø20mm
De qualité mais compliqué
La prise est certainement de très bonne qualité, mais connecter le cable, surtout si de diamètre un peu important, est pas mal compliqué. Je crois qu'on aurait pu la concevoir mieux. Le coté IEC est beaucoup plus simple.
This Viborg VE512G Schuko power connector is of exceptional design quality, using only the highest quality materials to ensure the best possible...
