DAYTON AUDIO CC80W 2-Way In-Ceiling Speaker
The Dayton Audio CC80W is a in-ceiling speaker designed for fixed stereo or multi-zone installations. Its 2-way design combines a 203mm polypropylene cone woofer and a 13mm PEI dome tweeter, offering balanced reproduction and good dispersion for discreet ceiling mounting.
Reference : 21278
169,00 €tax incl.
140,83 € tax excl.
Grantie 5 ans
Dayton Audio CC80W 2-Way In-Ceiling Speaker 50W 8 Ohm Ø20.3cm + Ø1.3cm (Pair)
Dayton Audio CC80W-8 : Front view
Capable of delivering 50W RMS power under 8Ω, it connects directly to a standard amplifier and accepts wiring up to 2.08mm² (14 AWG). The removable front grille facilitates maintenance and allows for neat visual integration. Its robust construction makes it a reliable solution for music or audio signal distribution in environments requiring a discreet and high-performance built-in installation.
Product typeIn-Ceiling Speaker
Driver1x Woofer Ø203mm
1x Tweeter Ø13mm
Impedance8Ω
Power50W RMS
DimensionsWithout grid : 267 mm x 95 mm
With grid : 280 mm x 102 mm
Weight4.6kg
PackageSold by pair
Speaker Power (W RMS)50.0
Speaker TypeCeiling Speaker
Impedance (Ω)8
Loudspeaker diameter (mm)13.0
Loudspeaker diameter (mm)203.0
Diaphragm typePolypropylene
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)N/A
Highest frequency (Hz)N/A
DAYTON AUDIO CC80W 2-Way In-Ceiling Speaker 50W 8 Ohm Ø20.3cm + Ø1.3cm (Pair)
The Dayton Audio CC80W is a in-ceiling speaker designed for fixed stereo or multi-zone installations. Its 2-way design combines a 203mm...
