DOUK AUDIO Z1 Gaming Headphone Amplifier
The DOUK AUDIO Z1 is a desktop headphone amplifier and USB DAC designed for Hi-Fi and gaming, combining music playback, microphone management and mixing functions in a single device. It integrates an ESS9039Q2M converter and supports up to 24bit / 192kHz via the optical input, while its PC-USB input accepts signals up to PCM 16bit / 48kHz.
Reference : 22463
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 19-11-2026.
Douk Audio Z1 Gaming Headphone Amplifier ESS9039Q2M DAC MUSES01 24bit 192kHz
DOUK AUDIO Z1
The Douk Audio Z1 is a desktop headphone amplifier and USB DAC designed for Hi-Fi and gaming, combining music playback, microphone management and mixing functions in a single device. It integrates an ESS9039Q2M converter and supports up to 24bit 192kHz via the optical input, while its PC-USB input accepts signals up to PCM 16bit 48kHz.
The Z1 features 3.5mm and 4.4mm balanced headphone outputs, with the latter delivering up to 430mW at 32Ω, compared to 300mW at 32Ω for the 3.5mm output. It accepts USB-C, optical and AUX sources, as well as microphones via XLR or 3.5mm Jack, with 48V phantom power for compatible microphones.
In USB mode, its mixing function allows USB, AUX and microphone signals to be combined and then sent to the headphones, AUX output and host computer, while a MIC OUT output can transmit the voice signal only. The Z1 also offers dedicated bass, midrange and treble controls, with a range of ±10dB for bass and ±6dB for midrange and treble, as well as 8 selectable DAC filter modes. Its physical controls, LED indicators and selectors allow quick management of sources, microphone and various audio settings.
Compatible with Windows, macOS, Linux, Android and iOS, it can be used with a PC, PS5, Nintendo Switch or smartphone for gaming, voice communications and music playback. Its frequency response extends from 20Hz to 20kHz (±0.5dB), with a THD+N of 0.001% and an SNR ≥110dB. Its aluminum chassis measures 160 × 118 × 40mm, providing a robust construction suited to desktop use.
DOUK AUDIO Z1
Overview of the Douk Audio Z1
Overview of the DOUK AUDIO Z1
1Treble adjustment
2Bass adjustment
3Midrange adjustment
4Input selection
5MIX selector
6Microphone Mute
7Input/Mix/Mute indicators
8Display
9Microphone volume
10Volume/Filter
11Op-amp socket
123.5mm headphone output
134.4mm balanced headphone output
143.5mm microphone input
15XLR / 6.35mm Jack combo microphone input
163.5mm AUX input / Microphone output
17XLR / 3.5mm AUX selector
1848V phantom power
19USB-C input
205V USB-C power input
21Toslink optical input
223.5mm AUX output
Technical Specifications
Product typeHeadphone amplifier DAC
DAC chipESS9039Q2M
Op-ampMUSES01
Inputs1x USB-C
1x Toslink optical
1x 3.5mm AUX Jack
1x XLR/6.35mm Jack microphone combo
Outputs1x 3.5mm headphone output
1x 4.4mm balanced Jack
1x 3.5mm AUX output
1x 3.5mm MIC output
Supported sampling ratesUSB: PCM 16Bits 48kHz
Toslink optical: PCM 24Bits 192kHz
Headphone output power3.5mm Jack: 300mW/32Ω
4.4mm balanced Jack: 430mW/32Ω
Frequency response20Hz-20KHz (±0.5dB)
THD+N0.001%
SNR≥110dB
Recommended headphone impedance16-300Ω
AUX output level2V
Input sensitivityAUX: 850mV
XLR MIC: 40mV
3.5mm MIC: 60mV
USB/OPT: 0dBFS
USB compatible systemsWindows/macOS/Linux/Android/iOS
Treble/Mid/Bass adjustment rangesBass:±10dB
Treble/Mid:±6dB
MixingUSB mode only
Microphone muteUSB mode only
DAC filters8 modes
Power supply5V DC / ≥2A via USB-C
Dimensions160 x 118 x 40mm
Gross weight1.51kg
Package contents1x Douk Audio Z1
1x Metal stand
1x 5V DC power adapter
1x USB-A to USB-C charging cable
1x USB-A to USB-C DATA cable
1x 3.5mm Jack cable
InputJack 3.5mm
InputXLR
InputJack 6.35mm
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9039Q2M
Max sampling rate192kHz
DOUK AUDIO Z1 Gaming Headphone Amplifier MUSES01 DAC ESS9039Q2M 24bit 192kHz
The DOUK AUDIO Z1 is a desktop headphone amplifier and USB DAC designed for Hi-Fi and gaming, combining music playback, microphone management and...
