DDHIFI BC150G-A2DC Balanced Headphone Cable 4.4mm Jack to A2DC 1.45m
The DD HIFI BC150G-A2DC is a balanced headphone cable designed to connect a device equipped with a 4.4mm balanced Jack output to a pair of headphones, replacing their original cable.
By buying this product you get 25 loyalty points
Reference : 22451
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 17-11-2026.
ddHiFi BC150G-A2DC Balanced Headphone Cable 4.4mm Jack to A2DC 4N Silver / 5N OCC Copper 1.45m
DD HIFI BC150G-A2DC
The ddHiFi BC150G-A2DC is a balanced headphone cable designed to connect a device equipped with a 4.4mm balanced Jack output to a pair of headphones, replacing their original cable. It features a 2+2+1 conductor architecture with separate conductors for positive and negative signals, combined with a symmetrical dual-strand structure and an external mesh shield. The signal conductors use high-purity 4N pure silver for the positive signals and high-purity 5N OCC copper for the negative signals, while the shielding layer is made of silver-plated OFC copper. This design is complemented by highly transparent SoftFlex PVC insulation, as well as a balanced 4.4mm jack connector made of an aluminum alloy and red sandalwood with small leaves. The BC150G is therefore intended for headphone configurations compatible with this connection, while prioritizing flexibility, shielding and the limitation of electromagnetic interference.
ddHiFi BC150G-A2DC: Balanced Architecture and High-Purity Conductors
The BC150G uses a 2+2+1 structure in which the positive and negative signal conductors are made from different materials. Each signal consists of two sets of twisted conductors, while a shielding mesh surrounds the entire assembly. This dual-strand architecture improves cable flexibility during handling and limits the internal mechanical stress exerted on the conductors. The parallel twisted structure also helps reduce electromagnetic interference during signal transmission. The signal conductors are specified as 22.9AWG ×2 and use 4N pure silver for the positive signal and 5N OCC copper for the negative signal.
DD HIFI BC150G-A2DC: Balanced Architecture and High-Purity Conductors
ddHiFi BC150G-A2DC: Floating Shielding and 4.4mm Balanced Connection
The cable features a floating shielding system: the external shielding mesh is isolated from the housing of the 4.4mm Jack connector and remains floating at both ends. This design aims to eliminate ground-related interference that may occur between certain audio devices. The shielding is made of silver-plated OFC copper and has a cross-section of 21.5AWG ×2. The cable also features a high-transparency SoftFlex PVC jacket, while the connector housings combine aluminum alloy and small-leaf red sandalwood. The main connector is a 4.4mm balanced Jack, intended to be connected to a balanced headphone output.
DD HIFI BC150G-A2DC: Floating Shielding and 4.4mm Balanced Connection
Technical Specifications
Product TypeBalanced headphone cable
Connector1x 4.4mm Jack Termination
2x A2DC
Conductor MaterialsPositive Signal: 4N Silver
Negative Signal: 5N OCC Copper
Shielding: Silver-Plated OFC Copper
Insulation MaterialSoftflex PVC
Connector HousingAluminum Alloy + Red Sandalwood
Examples of Compatible HeadphonesFocal Utopia & compatible models
Length145cm
Weight65g
Packaging1x ddHiFi BC150G-A2DC Headphone Cable
Length (m)1.45
ShieldingYes
Section (mm²)0.258
ConnectorA2DC
ConnectorJack 4.4mm
Conductors material (Cable)Silver
DD BC150G-A2DC Balanced Headphone Cable 4.4mm Jack to A2DC 4N Silver / 5N OCC Copper 1.45m
The DD HIFI BC150G-A2DC is a balanced headphone cable designed to connect a device equipped with a 4.4mm balanced Jack output to a pair of...
