HIDIZS ST2 PRO USB-C to MMCX Headphone Cable
-20%
The Hidizs ST2 Pro earphone cable features an ES9281AC PRO DAC chip capable of processing PCM signals up to 32-bit/384 kHz as well as DSD128. This compatibility extends to MQA decoding to take advantage of compatible streaming catalogues. In terms of measured performance, the amplifier delivers 70 mW per channel under 32 Ω with a harmonic distortion rate of 0.0012%, while the signal-to-noise ratio reaches 118 dB and the dynamic range 122 dB, ensuring accurate reproduction even on the most nuanced passages.
Reduced price!
Reference : 21360
69,00 €tax incl.
-20%
55,20 €tax incl.
46,00 € tax excl.
Shipping date: 24-11-2026.
Hidizs ST2 Pro USB-C to MMCX Headphone Cable DAC ES9281AC PRO 32bit 384kHz DSD128
Hidizs ST2 Pro : Front view
Product typeHeadphone cable
Portable DAC
Connectors1x USB-C
2x MMCX
Length1.2m
DAC chipES9281AC PRO
Supported sampling ratesPCM 32bit 384kHz
DSD128
MQA
Frequency response20Hz-40kHz
Sensitivity108dB
Impedance32Ω
Signal-to-noise ratio (SNR)118dB
Dynamic range122dB
Total harmonic distortion (THD)0,0012 %
Output power2x70mW @32Ω
Conductive materialOFC copper
Blue
Weight16g
Package1x Hidizs ST2 Pro
USB-A to USB-C adapter
OutputMMCX
DAC / ADC ChipES9281AC
Max sampling rateDSD128
Max sampling rate384kHz
ColorBlue
Length (m)1.2
ShieldingNo
Section (mm²)N/A
ConnectorMMCX
ConnectorUSB-C
HIDIZS ST2 PRO USB-C to MMCX Headphone Cable DAC ES9281AC PRO 32bit 384kHz DSD128
The Hidizs ST2 Pro earphone cable features an ES9281AC PRO DAC chip capable of processing PCM signals up to 32-bit/384 kHz as well as DSD128. This...
