FIIO LL-3.5A Headphone Cable with Microphone 1.5m + 0.6m
The FiiO LL-3.5A is a replacement headphone cable with a boom microphone, designed to transform compatible headphones into a true communication or gaming headset.
Reference : 22257
19,00 €tax incl.
15,83 € tax excl.
FIIO LL-3.5A
The FiiO LL-3.5A is a replacement headphone cable with a boom microphone, designed to transform compatible headphones into a true communication or gaming headset. It features two 3.5mm TS connectors on the headphone side and a 3.5mm TRRS plug on the source side, allowing both audio and microphone signals to be transmitted through a single connection. Its omnidirectional microphone, mounted on a flexible boom arm, is protected by a high-density windscreen, ensuring clear voice capture during calls, video conferences, or gaming sessions. The cable is made from silver-plated OFC copper conductors to ensure excellent signal transmission, while its TPE insulation covered with a braided fabric sleeve provides both flexibility and durability. It comes with a 0.6m extension cable featuring two 3.5mm TRS plugs (headphone and microphone) and one 3.5mm TRRS female jack, allowing easy connection to computers equipped with separate audio inputs. The main cable measures 1.5m, for a total length of 2.1m when used with the extension cable. It is compatible with numerous FiiO headphones as well as several models using dual 3.5mm TS inputs, including those from HiFiMAN, Meze, and Aune.
Technical Specifications
Product TypeHeadphone cable with microphone
ConnectorsCable:
1x 3.5mm TRRS Jack / 2x 3.5mm TS Jack
Extension cable:
1x 3.5mm TRRS Female Jack / 2x 3.5mm TRS Jack
Conductor MaterialSilver-plated OFC copper
InsulationTPE
MicrophoneOmnidirectional
LengthCable: 1.5m
Extension cable: 0.6m
Package Contents1x FIIO LL-3.5A Cable
1x Extension Cable
Length (m)0.6
Length (m)1.5
ShieldingNo
Section (mm²)N/A
ConnectorJack 3.5mm
The FiiO LL-3.5A is a replacement headphone cable with a boom microphone, designed to transform compatible headphones into a true communication or...
