MOONDROP MIS-TIP T41-S IEM Ear Tips Small (Pair)
The Moondrop MIS-Tip T41 are memory foam ear tips designed to optimise the interface between the IEM and the ear canal, relying on a 4.1mm inner diameter to ensure stable mechanical compatibility with IEM nozzles ranging from 4.4 to 5.8mm. This dimensional match allows uniform retention without excessive stress, while promoting a gradual insertion that improves acoustic seal and positional stability.
Reference : 22122
9,00 €tax incl.
7,50 € tax excl.
Shipping date: 17-11-2026.
Moondrop MIS-TIP T41-S Foam IEM Ear Tips Ø4.1mm Small (Pair)
MOONDROP MIS-TIP T41-S : Front view
MOONDROP MIS-TIP T41-S : Frequency response curve
Intended for single dynamic driver IEMs, they leverage the expansive properties of foam to conform to the morphological variations of the ear canal, limiting acoustic leakage while stabilising the perceived frequency response.
Technical caracteristics
Product typeIEM ear tips
Inner diameterØ4.1mm
MaterialMemory foam
Compatible IEM nozzle diameterØ4.4-5.8mm
PackageSold as a pair
MOONDROP MIS-TIP T41-S Embouts pour Écouteurs Intra-Auriculaires Mousse Ø4.1-5.8mm Small (Pair)
The Moondrop MIS-Tip T41 are memory foam ear tips designed to optimise the interface between the IEM and the ear canal, relying on a 4.1mm inner...
