By buying this product you get 61 loyalty points
Lecteur CD Sanyo DA11 Burr-Brown PCM1732
The McGee CD-M1 is a high-end CD player, based on the high-quality Sanyo DA11 optical drive, installed in a robust aluminium case. The player has a full range of connections with two stereo RCA outputs as well as Optical Toslink and Coaxial outputs. The digital/analog conversion of the CD-M1 is done by a Burr-Brown PCM1732 DAC chip.
The power stage of the CD-M1 is also optimized and totally separated from the player so that no interference can alter the audio signal.
Product type | CD Player |
Optical drive | Sanyo D11 |
DAC Chip | Burr-Brown PCM1732 |
Outputs | 2x Stereo RCA 1x Optical Toslink 1x Coaxial |
THD | < 0.008% |
Frequency response | 20Hz - 20kHz |
Output impedance | 800Ω |
SNR | > 90dB |
Supply voltage | 230VAC 50Hz |
Consumption | Max : 35W Idle : 6.9W |
Dimensions | 351 x 258 x 74mm |
Weight | 4.5kg |
Color | Black |
Housing material | Aluminum |
Package | 1x McGee CD-M1 1x Power cable 1x Remote control 2x RCA Cables (L/R) |
