SHANLING EC ZERO T MAX CD Player
The Shanling EC ZERO T MAX is a portable battery-powered audiophile CD player that also functions as a high-resolution USB DAC and Bluetooth 5.3 transmitter.
By buying this product you get 68 loyalty points
Reference : 22356
689,00 €tax incl.
574,17 € tax excl.
Shanling EC ZERO T MAX Portable Battery-Powered R2R CD Player JAN6418 AD8397 Bluetooth 5.3 32bit 768kHz DSD512
The Shanling EC ZERO T MAX is a portable battery-powered audiophile CD player that also functions as a high-resolution USB DAC and Bluetooth 5.3 transmitter. It combines Shanling's proprietary R2R digital architecture with an analog output stage featuring dual Raytheon JAN6418 vacuum tubes, complemented by a headphone amplifier based on AD8397 operational amplifiers. This design delivers a warm and detailed musical presentation from both CDs and external digital sources. In USB DAC mode, the EC ZERO T MAX supports PCM streams up to 32bit / 768kHz as well as DSD512, while its Bluetooth 5.3 transmission is compatible with aptX Adaptive, aptX, and SBC codecs. It features a balanced 4.4mm headphone output delivering up to 1300mW into 32Ω, as well as a single-ended 3.5mm output delivering 330mW into 32Ω, complemented by 4.4mm and 3.5mm line outputs for seamless integration into a HiFi system. Its Philips CD mechanism with anti-vibration design, 1.68" IPS color display, JRC analog volume control, and integrated 5500mAh battery providing up to 8 hours of playback make the Shanling EC ZERO T MAX a comprehensive audiophile solution for enjoying CDs and digital sources both on the go and at home.
Shanling EC ZERO T MAX: R2R Architecture Combined with Dual JAN6418 Tubes
The Shanling EC ZERO T MAX combines a proprietary R2R DAC with an analog output stage built around two genuine Raytheon JAN6418 subminiature vacuum tubes. This combination delivers a natural and organic sound while maintaining excellent precision and resolution. The headphone stage is based on AD8397 operational amplifiers capable of efficiently driving both in-ear monitors and demanding audiophile headphones, delivering up to 1300mW into 32Ω via the balanced 4.4mm output.
Shanling EC ZERO T MAX: CD Player, High-Resolution USB DAC and Bluetooth 5.3 Transmission
Much more than a portable CD player, the EC ZERO T MAX can also be used as a high-resolution USB DAC supporting PCM up to 32bit / 768kHz and DSD512. Its Bluetooth 5.3 connectivity enables wireless audio transmission with support for aptX Adaptive, aptX, and SBC codecs. It therefore serves as a versatile audio source capable of playing both CDs and audio files from a computer, smartphone, or tablet while transmitting the audio stream to Bluetooth speakers or headphones.
Shanling EC ZERO T MAX: Comprehensive Connectivity and Portable Audiophile Design
The Shanling EC ZERO T MAX offers extensive connectivity, including single-ended 3.5mm and balanced 4.4mm headphone outputs, rear-panel line outputs complemented by a 3.5mm SPDIF output, as well as a USB-C input dedicated to USB DAC operation.
Its Philips CD mechanism features an optimized anti-vibration design to ensure stable disc playback, while its 1.68" IPS display, JRC analog potentiometer, and rechargeable 5500mAh battery providing up to 8 hours of playback ensure comfortable operation both on the move and as part of a home HiFi system.
Technical Specifications
Product TypeCD Player
InputCD
1x USB-C DAC Input
Outputs1x 3.5mm Single-Ended Headphone Output
1x 4.4mm Balanced Headphone Output
1x 3.5mm Single-Ended Line Output
1x 4.4mm Balanced Line Output
1x Coaxial / Optical SPDIF Output
Bluetooth
DAC24-bit R2R
USB DAC SupportPCM up to 32bit 768kHz
DSD up to DSD512
Display1.68" LCD
Digital FilterNOS
OS
Bluetooth Version5.3
Supported Bluetooth Transmission CodecsaptX Adaptive
aptX
SBC
Frequency Response20Hz-40kHz (-0.5dB) (USB DAC)
20Hz-20kHz (-0.5dB) (CD)
CD Ripper
Gapless Playback
Output Power (Transistor Mode)Low Gain: 37mW @ 32Ω
High Gain: 361mW @ 32Ω
High Gain (External Power): 361mW @ 32Ω
Output Power (Tube Mode)Low Gain: 39mW @ 32Ω
THD+N0.02% (Transistor)
1% (Tube)
Dynamic Range115dB
Channel Separation79dB
Signal-to-Noise Ratio (SNR)115dB
Noise (Low Gain)110dB
Output Impedance0.4Ω
Output Power (Transistor Mode)Low Gain: 211mW @ 32Ω
High Gain: 1300mW @ 32Ω
High Gain (External Power): 1300mW @ 32Ω
Output Power (Tube Mode)Low Gain: 151mW @ 32Ω
High Gain: 1162mW @ 32Ω
High Gain (External Power): 1162mW @ 32Ω
1% (Tube)
Dynamic Range116dB
Channel Separation103dB
Signal-to-Noise Ratio (SNR)116dB
Noise (Low Gain)107dB
Output Impedance0.7Ω
Output Level (Transistor Mode)2.12Vrms
Output Level (Tube Mode)1.8Vrms
1% (Tube)
Output Level (Transistor Mode)4.2Vrms
Output Level (Tube Mode)3.6Vrms
1% (Tube)
Signal-to-Noise Ratio (SNR)117dB
Power Supply5V / 2A
Dimensions158 x 150 x 28mm
Weight669g
ColorSilver
Package Contents1x Shanling EC Zero T
1x USB-A to USB-C Cable
SHANLING EC ZERO T MAX CD Player on Battery R2R JAN6418 AD8397 Bluetooth 5.3 32bit 768kHz DSD512
The Shanling EC ZERO T MAX is a portable battery-powered audiophile CD player that also functions as a high-resolution USB DAC and Bluetooth 5.3...
