By buying this product you get 54 loyalty points
-20,00 €
This Topping pack includes the E50 DAC, PA5 II PLUS amplifier and TCT1 TRS 6.35mm jack cables for balanced interconnection. This package gives you a complete, affordable, high-performance audio system, capable of delivering rich, accurate sound.
Topping's PA5 II Plus amplifier is a compact and powerful model, adopting a totally symmetrical structure and an innovative Class D amplification circuit, enabling it to develop a significant power of 2x125W into 4Ω with a low level of distortion. The excellent parameterization carried out by the brand's engineers ensures clear, clean and deep sound reproduction, with no background noise. At 5W and 4Ω, THD+N is measured at less than 0.0004%. The PA5 II Plus also incorporates an effective and comprehensive protection circuit, acting against overvoltage, undervoltage, short-circuit, overcurrent and overheating.
On the input side, there's a choice of unbalanced stereo RCA or two 6.35mm TRS jacks for balanced input. Output is via conventional banana-plug HP terminals. There's also a 12V trigger on the rear of the unit, enabling the PA5 II Plus to be connected to other devices and benefit from automatic on/off.
With its E50, Topping offers a compact, high-performance DAC using tried-and-tested audio components widely recognized by audiophiles. It's based on an ESS ES9068AS digital/analog conversion chip and an XMOS XU216 USB interface, enabling it to read high-resolution files as well as decode MQA files. It also features a balanced output on TRS connectors.
FIND OUT MORE ABOUT TOPPING E50
Topping's TCT1 cables are high-quality 6.35mm jack cables. They feature 6N copper and 6N silver-plated copper conductors for perfect signal transmission. Each conductor has a cross-section of 0.533mm² (19AWG). Connector contacts are gold-plated for excellent conductivity and resistance to oxidation. Each cable is covered by a robust black and red braided nylon sheath.
MORE ABOUT TOPPING TCT1Caractéristiques techniques
| Topping PA5 II PLUS Full specifications | |
| Product type | Amplifier |
| Amplification type | Class D |
| Inputs | 1x Single-ended stereo RCA 1x Balanced dual Jack 6.35mm TRS |
| Output | Speaker terminals |
| 12V trigger | Yes |
| Full specifications on the PA5 II Plus page | |
| Topping E50 Specifications | |
| Product type | DAC |
| DAC chip | ES9068AS |
| USB interface | XMOS XU216 |
| Inputs | 1x USB-B 1x Coaxial 1x Optical Toslink |
| Outputs | 1x Single-ended stereo RCA 1x Balanced dual Jack 6.35mm TRS |
| Supported sampling rates | PCM up to 32bit 768kHz Native DSD up to DSD512 MQA |
| Remote control | Yes |
| Full specifications on the E50 page | |
| Topping TCT1 specifications | |
| Product type | Balanced Jack 6.35mm TRS cables |
| Connectors | Male Jack 6.35mm TRS |
| Length | 25cm |
| Outer cable diameter | Ø8mm |
| Conductors material | Copper Silver plated copper |
| Conductors section | 0.533mm² (19AWG) |
| Connectors contacts plating | Gold |
| Outer sheath | Braided nylon |
| Sheath color | Black and red |
