USB 5V Supercapacitor Filter
This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer system. Input is via a USB-C port and output via a USB-C or USB-A port.
4.8 / 5
Reference : 18529
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 18-06-2026.
USB 5V Supercapacitor Filter USB-C to USB-C / USB-A
Photo of USB 5V Supercapacitor Filter
This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer system, a Mosfet ME85P03 transitor, an STC 8H1K08 microcontroller and an AMS1117 advanced monolithic voltage regulator. Input is via a USB-C port and output via a USB-C or USB-A port. There are also LEDs to indicate when the USB filter is charging: 10%, 25%, 50%, 75%, 100%. This USB filter can be powered with a standard 5V 3A USB charger, but can also be placed between a computer and a DAC. For example, it can be used as the input or output of a Raspberry PI.
Product typeUSB filter
Input1x USB-C
Outputs1x USB-C
1x USB-A
Dimensions80 x 42mm
ColorSilver
Weight100g
Package1x 5V USB filter
OutputUSB
ColorSilver
Output voltage (V)5.0
Output current (A)NC
Input voltage (V)5.0
Power SupplyPower supply filter
6 reviews
Noticeably improved the sound in my system
I'm using this filter with an iFi SPDIF iPurifier2, which gets its power from a computer USB port. It's reclocking the Toslink signal coming from a Samsung TV. I'm also using an Audiophonics Digirescue after the iFi unit to reclock the signal one more time. The Digirescue is powered by an iFi Elite. Using both of these units in this specific order, with iFi first and Digirescure second, makes the sound by far the best in my system. I've tried every other combination of using no reclocker, only one reclocker powered by iFi Elite, and the two at the same time. Using both sounds best, and by adding this Supercapacitor filter for the iFi and its dirty PC power source made the sound leap to the next level.
I also have a USB source, and before I added this Supercapacitor filter the SPDIF source was a bit worse than my USB source. But with this filter in place the SPDIF signal is now better than USB by a comfortable margin. These supercapacitor filter products are probably the most cost effective method of removing power noise. In my system it exceeded expectations. Highly recommended!
This review has been posted for USB 5V Supercapacitor Filter USB-C to USB-C / USB-A
Efficace mais manque un interrupteur on/off
Utilisé entre une alimentation linéaire 5v Audiophonics et un Ifi Audio LAN ipurifier pro, ce filtre améliore sensiblement la perception des détails.
J'enlève malgré tout une étoile pour l'absence d'interrupteur on / off, qui entraîne durant la phase d'allumage (charge du supercap - environ 30s à 1 min) et d'extinction une sous-tension en sortie.
De fait on voit l'ifi audio Ipurifier pro clignoter, lumières faiblardes, reboot en boucle... pas sûr que ca lui fasse du bien.
Pour éviter cela, je dois attendre à l'allumage que la charge du supercap soit terminée avant de brancher le câble d'alimentation usb en sortie.
Et a l'extinction, débrancher le câble l'alimentation usb avant de couper l'alimentation secteur.
Les autres filtres usb supercap proposés par Audiophonics (non usb) ont ce bouton on/off qui doit résoudre le problème
Efficace
Sur Raspberry Pi 4 avec hat Hifiberry Digi + et tournant sous gentoo player : l'apport est notable. Indéniable même.
Le RP4 était déjà alimenté sur une alimentation linéaire Tomanek, mais en intercalant ce filtre, le gain est notable.
Éclaircissement de la scène, recul du bruit de fond, meilleure définition des instruments.
A conseiller donc, notamment pour ceux qui utilisent un RPi comme steamer.
seul bémol : tous les deux utilisant le même principe d'intercaler des condensateurs sur le flux DC, un peu cher en comparaison d'un filtre FX-Audio Susie, par exemple, qui embarque lui des condensateurs Nichicon pour 1/3 du prix.
Good improvement
Placed between an iFi iPower 5v and a Topping 30 II, it improves clarity and detail.
It won't have the performance of expensive linear power supplies but it holds up well.
Recommended
Efficace !
Utilisé sur l'alim d'un DAC Topping E30 Lite, raccordé en usb à un Raspberry Pi4/Moode Audio.
Le Dac était auparavant alimenté par un bloc secteur Meanwell à découpage, désormais remplacé par un chargeur smartphone faible bruit (ça existe) + filtre USB à supercondensateurs.
L'aigu a perdu son côté un poil "piquant" mais reste lumineux et détaillé, et surtout mieux intégré au reste du spectre.
J'ai une alim linéaire LDOVR LT3045 qui subjectivement ne fait pas mieux, y compris sur le fameux "silence entre les notes".
Bien que le DAC soit ultra silencieux, il laissait visiblement passer des résidus HF du bloc secteur à découpage, ce que ce petit filtre nettoie de façon audible.
This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors...
