DOUK AUDIO D2 Linear Power Supply 5V
The Douk Audio D2 is a 5V linear power supply designed to deliver stable, low-noise DC voltage to digital audio equipment, providing up to 15W at 2.5A. It relies on a regulated architecture integrating an encapsulated transformer, an LM1085IT regulator and low-ESR capacitor filtering to reduce ripple and interference, allowing sensitive circuits to be powered from a cleaner electrical foundation.
Reference : 22164
89,00 €tax incl.
74,17 € tax excl.
Douk Audio D2 Linear Power Supply Jack DC / USB 5V 2.5A
Douk Audio D2 : Front view
Intended for compact Hi-Fi installations and computer audio environments, it combines power supply stability, dual USB-A and DC outputs and straightforward integration, enabling two 5V devices to be powered from a single unit. This approach allows it to serve as a dedicated power source within a digital chain, while maintaining stable and consistent operation over time.
Douk Audio D2: Low-noise linear power supply
The Douk Audio D2 is a 5V linear power supply designed to deliver stable, low-noise DC voltage, relying on an encapsulated transformer paired with an LM1085IT regulator and Panasonic FM capacitors to smooth the output voltage and reduce residual ripple effectively. This architecture achieves a ripple level below 20µV under no load, while limiting switching supply interference, resulting in a lower noise floor and improved retrieval of fine detail on sensitive audio circuits.
Douk Audio D2 : Voltage regulator
Douk Audio D2 : USB and DC Jack outputs
Douk Audio D2: Dual 5V output
Beyond electrical stability, the D2 delivers 15W with a current output of up to 2.5A, enabling consistent powering of 5V devices. The dual USB-A and DC output configuration allows two pieces of equipment to be powered simultaneously, enabling power sources to be centralised within a compact installation while maintaining stable and uniform distribution.
Douk Audio D2: Aluminium chassis
This approach extends to a CNC-machined aluminium chassis, which contributes to reducing electromagnetic interference while improving thermal dissipation of the internal components. This design ensures operational stability under sustained use, while facilitating integration into a desktop Hi-Fi environment or compact audio setup requiring a clean and reliable power source.
Aluminium chassis
Product typeLinear power supply
Outputs1x USB-A
1x DC Jack 5.5/2.5mm (5.5/2.1mm compatible)
Nominal output voltage5V
Nominal output current2.5A
Ripple noiseNo load <23µV
Power supply voltage220V–240V AC
Power consumption15W
Dimensions125 × 80 × 40mm
Weight600g
Package1x Douk Audio D2
1x DC Jack cable
1x Power cable
InputIEC C14
OutputUSB
OutputJack DC 5.5/2.5mm
Output voltage (V)5.0
Output current (A)2.5
Input voltage (V)120.0
Input voltage (V)230.0
Power SupplyLinear
DOUK AUDIO D2 Linear Power Supply Jack DC / USB 5V 2.5A
The Douk Audio D2 is a 5V linear power supply designed to deliver stable, low-noise DC voltage to digital audio equipment, providing up to 15W at...
