FOSI AUDIO DC Power Noise Filter 12-55V 10A with DC jack doubler
This Fosi Audio power supply noise reducer accepts a voltage range of 12V to 55V and a current of 10A via DC 5.5/2.5mm jack. It reduces power supply noise and protects your equipment from electromagnetic interference, thanks to filter capacitors and inductors.
Reference : 19692
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 04-11-2026.
Photo of Fosi Audio power supply noise reducer
This Fosi Audio power supply noise reducer accepts a voltage range of 12V to 55V and a current of 10A via DC 5.5/2.5mm jack. It reduces power supply noise and protects your equipment from electromagnetic interference, thanks to  filter capacitors and inductors. Another advantage of this power noise reducer is that it reduces the impact of power surges and spikes on devices, thus extending their life. A doubler DC 5.5/2.5mm jack is also supplied, enabling two devices to be powered simultaneously.
Product typePower supply filter
Operating voltage12-55V DC
Max. operating current10A
ConnectorsJack DC 5.5/2.5mm
Package1x Fosi Audio power noise reducer
1x DC 5.5/2.5mm jack doubler
InputJack DC 5.5/2.5mm
OutputJack DC 5.5/2.5mm
Output voltage (V)55.0
Output voltage (V)12.0
Output current (A)10.0
Input voltage (V)12.0
Input voltage (V)55.0
Power SupplyPower supply filter
5 reviews
A essayer
Dans tous les cas, et à ce prix, ce serait dommage de ne pas tester ce petit module dont l'insertion apporte un plus difficile à quantifier, mais non négligeable: il semble que la précision de placement et la construction de l'image stéréo soient les principales bénéficiaires, un peu à l'image de l'apport d'une alim linéaire régulée.
This review has been posted for FOSI AUDIO DC Power Noise Filter 12-55V 10A with DC jack doubler
amélioration évidente d'une alimentation 32v 6A
Utilisé avec une alimentation 32v 6A vendue sur ce site , le gain en propreté (timbres) est très net. Merci
Cout faible pour résultat concluant
Connecté à un préampli à tubes AYIMA : ouverture de la scène sonore importante sans brider le son ni le colorer . Recommandable .
Worth every penny!
I have two of these filters in use. One is connected to the power supply of my ASUS NUC, which I use exclusively as a Roon Core. The other is connected to the power supply of my router, a Fritz!Box 6591 Cable. In both cases, the high-frequency noise of the switching power supplies is significantly reduced by using the Fosi filters. With an oscilloscope and an 8-ohm load (50 Watt), I measured 140mV AC ripple on the Delta (Brandname) switching power supply of my Roon Core for example. With the filter, this is reduced to only 16mV AC ripple, which consists almost entirely of 50 Hz residual noise from the mains voltage. The high-frequency noise has disappeared. However, with the Delta power supply of the ASUS NUC, it shuts down as soon as the filter is connected. You have to disconnect the Delta from the mains first, then connect the filter, and then you can connect the Delta power supply to the mains without any problems.
Dynamique
J'ai essayé ce filtre qui m'apporte du silence, de la dynamique, des détails et un médium plus naturel. C'est une bonne solution pour améliorer les alimentations "sales" qui pullulent sur le marché actuel de la hifi.
C'est bien, c'est peu coûteux et ça marche... sensiblement.
This Fosi Audio power supply noise reducer accepts a voltage range of 12V to 55V and a current of 10A via DC 5.5/2.5mm jack. It reduces power...
