FOSI AUDIO PSU20 Linear Power Supply
The Fosi Audio PSU20 is a linear power supply designed to provide a stable electrical source to Hi-Fi and sensitive electronic devices. Its 80 W toroidal transformer feeds a 40 W regulation stage, while its three isolated outputs allow several devices to be powered simultaneously with a ripple level limited to 0.1 mV.
By buying this product you get 23 loyalty points
Reference : 22359
239,00 €tax incl.
199,17 € tax excl.
Shipping date: 20-11-2026.
FOSI AUDIO PSU20 Linear Power Supply DC Jack / USB 5V 12V 15V
FOSI AUDIO PSU20: Front view
The Fosi Audio PSU20 is a linear power supply designed to provide a stable electrical source to Hi-Fi and sensitive electronic devices. Its 80W toroidal transformer feeds a 40W regulation stage, while its three isolated outputs allow several devices to be powered simultaneously with a ripple level limited to 0.1mV.
Intended for audio setups requiring a clean and properly filtered power supply, it combines two DC jack outputs at 5/12 V and 12/15 V with a USB-A 5 V output. Its built-in protections and active cooling, triggered from 55 °C, help maintain stable operation while keeping the noise level down to 30 dB.
Fosi Audio PSU20: 40W linear power supply
The Fosi Audio PSU20 is a 40 W linear power supply based on an 80W toroidal transformer. This architecture provides a regulated voltage while limiting the interference generated by the power supply, in order to suit audio devices requiring a stable electrical source.
FOSI AUDIO PSU20: Transformer
FOSI AUDIO PSU20: 3 isolated outputs
Fosi Audio PSU20: Isolated outputs
The PSU20 features three fully isolated outputs: two DC jack outputs at 5/12V and 12/15 V and a USB-A 5 V output. This electrical separation allows several devices to be powered simultaneously while limiting interactions between the various circuits, particularly in setups combining a digital source, DAC and amplifier.
Fosi Audio PSU20: Regulation and noise level
The power stage uses Nippon Chemi-Con capacitors as well as three LM1085IT regulators and one ST78M05 regulator from Texas Instruments. This combination achieves a ripple of 0.1mV, in order to reduce the parasitic components likely to affect sensitive audio circuits.
FOSI AUDIO PSU20: Capacitors
FOSI AUDIO PSU20: Protection
Fosi Audio PSU20: Protection and cooling
The PSU20 monitors its operating conditions to protect itself against overheating, overvoltage and overload. When the temperature reaches 55 °C, a fan starts up to dissipate the heat; its noise level limited to 30dB preserves the discretion of the power supply within a Hi-Fi setup.
Technical specifications
Product typeLinear power supply
Outputs2x DC Jack 5.5/2.5
1x USB-A
Output voltage / currentDC Jack 1: 12V / 15V (Rated Power: 20W)
DC Jack 2: 12V / 5V (Rated Power: 15W)
USB-C: 5V / 1A (Rated Power: 5W)
Ripple noise0.1mV
Supply voltage100–120V AC
220–240V AC
Package1x Fosi Audio PSU20
2x DC Jack cable
1x Power cable
InputIEC C14
OutputUSB
OutputJack DC 5.5/2.5mm
Output voltage (V)15.0
Output voltage (V)12.0
Output voltage (V)5.0
Output current (A)1.0
Input voltage (V)230.0
Input voltage (V)110.0
Power SupplyLinear
Excellente et surprenantes qualités d'écoute.
J'avais d'abord choisi une alimentation linéaire Allo Shanti pour alimenter mon lecteur réseau Lindemann Limetree Network II en 5 volts. Mais j'ai changé d'avis, gêné par les câbles DC solidaires. Et puis j'étais curieux de tester l'alimentation linéaire FOSI Audio PSU20, avec l'avantage de proposer une sortie DC 5/12 volts réglable et une seconde de (15/12 volts réglable) qui me permettrait de connecter le switch Buffalo et de supprimer son alimentation linéaire spécifique.
Le résultat avec un câble secteur Furutech OCC m'a énormément surpris ! Aucune acidité, mais une dynamique étonnante et une nette amélioration par rapport à celle du Buffalo (Chinoise mais qualitative, transformateur R core). Aucun bruit de ventilateur et chauffe contenue sur des sources.
Elle mérite une attention des audiophiles exigeants avec son tarif plutôt contenu, elle présente un excellent rapport qualité / prix.
Conseillée !
This review has been posted for FOSI AUDIO PSU20 Linear Power Supply DC Jack / USB 5V 12V-15V
The Fosi Audio PSU20 is a linear power supply designed to provide a stable electrical source to Hi-Fi and sensitive electronic devices. Its 80 W...
